» I Was Bored
by Tagg Today at 11:11 pm
» Stock seat mods
by honda_silver Today at 8:50 pm
» Headlight Question
by OldRacer67 Today at 7:49 pm
» Silverwing or Burgman 650....not again!
by OldRacer67 Today at 7:46 pm
» Does anyone have the Side Case Attachments on SW 600
by bigbird Today at 7:15 pm
» Engine Turn off
by honda_silver Today at 6:17 pm
» Front fork seal leaking
by Waspie Today at 1:01 pm
» interior light with manual switch
by model28a Today at 12:43 pm
» Corbin Seat More Leg Room
by honda_silver Today at 10:17 am
» Tailgaters - What to do?
by Walt981 Yesterday at 11:58 pm
» Today IS a good news day
by johnd Yesterday at 9:32 pm
» V belt light?
by johnd Yesterday at 9:27 pm
 Brake Fluid Replacement??
Number of posts: 2254
Registration date: 2008-12-23
PostSubject: Re: Brake Fluid Replacement??   Wed Mar 17, 2010 5:32 pm
I am looking at the Honda Service manual "Brake System" chart.
It shows
"DOT 4" . It does not show how much fluid for a complete brake fluid
change ... I am trying to determine how much Amsoil DOT-4 fluid I want
to order.
_________________
Bill - Georgetown TX 07 Silver Wing ABS
Clearview w/vent, Givi E96/TB19/E52 with Admore Lighting, Alaskan Leather, Wrist Rests, 3M Solas tape, K&N air, Hyperpro spring, Grip Puppies, Airhawk, Utopia backrest, Stebel, Apexcone HIDs, StingerZ LEDs (w/Backoff WigWag), Knight Rider Sequential LED, NGK Iridium, Power Commander III, Manic Salamander, Saeng mirrors, Garmin Zumo 660, Dark-Side Sumitomo Tire
MaxB
Number of posts: 302
Registration date: 2009-10-06
PostSubject: Re: Brake Fluid Replacement??   Wed Mar 17, 2010 8:15 pm
Things not mentioned:
1. Hondas do not use Silicon based brake fluid. You can use mineral based (like at most auto parts stores. DO NOT mix the 2 types. they are incompatible.
2. I have found that if you get air in the line at the upper cylinder, sometimes air gets caught in the banjo bolt on the master cylinder. To clear this air bubble , it is necessary to crack it and squeeze the lever and close while squeezing it to get that last bubble out.
I use the harbor freight suction type that was mentioned by Honda_silver. It is a good unit for the money.
MaxB
PostSubject: Re: Brake Fluid Replacement??   Thu Mar 18, 2010 6:09 am
I am curious how you found this??
How do you know if brake fluid is "Silicon based" or not then?
_________________
Number of posts: 1767
Registration date: 2008-12-24
PostSubject: Re: Brake Fluid Replacement??   Thu Mar 18, 2010 9:48 am
I'd say the standard "DOT 4" will cover the composition. DOT 3, DOT4, and DOT 5.1 are all polyethylene Glycol based. DOT 5 is Silicon based.
I know it is wikipedia, but you have to start somewhere: http://en.wikipedia.org/wiki/DOT_4
PostSubject: Re: Brake Fluid Replacement??   Thu Mar 18, 2010 10:04 am
What I meant is that the standard, which is DOT 4, defines the requirements for composition and performance. In the case of composition, the DOT 4 standard is similar to DOT 3 and DOT 5.1, but different from DOT 5.
The rest of the differences between the standards I do not know. I'm sure that data points such as boiling temps, viscosity, water absorbsion and many either things make up the DOT # standards.
Honda does specify DOT 4 for our SilverWings, but does not include the data Bill (honda_silver) is most interested in - how much is needed for a full flush.
» REAR DISK BRAKE SET RM450
» EVO UPGRADED BRAKE KIT FRONT - USE WITH 17x8J ET25 TOMBINOS
» New Billet LS430 Big Brake Adapters for Late offset (87-up NA)
» EVO UPGRADED BRAKE KIT REAR - USE WITH 17x8J ET25 TOMBINOS
» Is a brake fluid reservoir replacement possible?
