| dog carrier on Givi Monokey bracket? | |
stanly Scooter Rider
Number of posts : 49 Location : Eastern Washington Points : 4098 Registration date : 2013-04-05
| Subject: dog carrier on Givi Monokey bracket? Mon May 20, 2013 1:22 pm | |
| Givi Luggage (topcase)– is there a way to use their mount for something other than their luggage, say mounting a dog carrier? About a 40lb dog so the backpack type solution won't work. |
Colin B Silver Wing Expert
Number of posts : 586 Age : 72 Location : Windsor, UK Points : 4695 Registration date : 2013-03-20
| Subject: Re: dog carrier on Givi Monokey bracket? Mon May 20, 2013 1:59 pm | |
| If you remove the monokey plate (the thing like a toilet seat!) you should be left with brackets that are bolted to the swing luggage rack.
It should be fairly easy to bolt anything else to those.
Number of posts : 3294 Age : 84 Points : 9223 Registration date : 2009-08-18
| Subject: Re: dog carrier on Givi Monokey bracket? Mon May 20, 2013 4:22 pm | |
| 40pound dog on back way up high=might get you killed----GIVI box with hole cut in top works for under 10 lb dog----but you can still feel him there. My last dog, Moose rode to James Bay/Alaska/Baja/Europe/Korea that way. Old age got him.
GIVI "ears" can be used to bolt something else to. |
| Subject: Re: dog carrier on Givi Monokey bracket? Mon May 20, 2013 7:17 pm | |
| - Colin B wrote:
- If you remove the monokey plate (the thing like a toilet seat!) you should be left with brackets that are bolted to the swing luggage rack.
It should be fairly easy to bolt anything else to those. Can't picture this, whatever it is, mine doesn't have a hole in center. - john grinsel wrote:
- 40pound dog on back way up high=might get you killed----GIVI box with hole cut in top works for under 10 lb dog----but you can still feel him there. My last dog, Moose rode to James Bay/Alaska/Baja/Europe/Korea that way. Old age got him.
GIVI "ears" can be used to bolt something else to. is a pretty high suppose, dog smell in Givi box=??? plus box I have is small "ears"? Should I have mentioned that I'm not Givilingual? |
| Subject: Re: dog carrier on Givi Monokey bracket? Mon May 20, 2013 10:33 pm | |
| Is isn't the size of the box, it is the weight high above and to the rear of the axle.. 40 lb dog needs big box, too. |
| Subject: Re: dog carrier on Givi Monokey bracket? Tue May 21, 2013 2:04 am | |
| - stanly wrote:
- Can't picture this, whatever it is, mine doesn't have a hole in center.
You don't have this? Perhaps you have this? Whichever, the same principle should apply. The monokey plate will be bolted to metal plates (ears) which are in turn bolted to the bike. Remove the monokey plate and fix your dog box to the metal ears. However, comments above re weight and balance are valid and should be heeded. |
| Subject: Re: dog carrier on Givi Monokey bracket? Tue May 21, 2013 12:40 pm | |
However, comments above re weight and balance are valid and should be heeded. I want out and took another look with topcase off, I have view #1 I see - Under the monokey plate Valid points on having weight behind axle I'd like to retain the quick dismounting feature of the monokey system to mount different case/carrier. Guessing from the alt suggestions that you can't buy only a part that's the equivalent of a case attachment part seperate from the case? |
Number of posts : 4174 Location : York, North Yorkshire, England UK Points : 9185 Registration date : 2010-11-16
| Subject: Re: dog carrier on Givi Monokey bracket? Tue May 21, 2013 12:59 pm | |
| Givi dealers have a manual of replacement parts for every top box and side case in their entire range, just about every component is available. |
| Subject: Re: dog carrier on Givi Monokey bracket? Wed May 22, 2013 1:50 pm | |
| ^^^ thanks, I don't see anything like this on GiviUSA.
| Subject: Re: dog carrier on Givi Monokey bracket? Wed May 22, 2013 4:18 pm | |
| In US call GIVI USA---dealers for the most part know little |
Number of posts : 3788 Age : 74 Location : Seaham, Co Durham, UK Points : 9440 Registration date : 2009-06-29
| Subject: Re: dog carrier on Givi Monokey bracket? Wed May 22, 2013 4:45 pm | |
| I shouldn't think Givi include the part that fits on the plate in their spares list as it's an integral part of each bag and box. |
Somerled Maxi-Scooter Rider
Number of posts : 177 Age : 62 Location : Fort Bliss, TX Points : 4911 Registration date : 2011-06-02
| Subject: Re: dog carrier on Givi Monokey bracket? Sat Jun 22, 2013 5:29 pm | |
| Yeah, I wouldn't recommend a 40 lb dog on the back of the Swing either. If you want a safe answer (if not an inexpensive answer) I would recommend the Bushtec Tow-Tow trailer. Quite happy with mine! https://www.silverwing600.com/t4519-dog-trailer |
| Subject: Re: dog carrier on Givi Monokey bracket? | |
