| MFD Odometer software change - Miles to Km? | |
+7tarmacburner2 "Hi Yo" LTU-013 model28a joncallihan rollsroyce250 swiss_steve 11 posters |
swiss_steve Scooter Rider
Number of posts : 8 Age : 64 Location : Switzerland Points : 4245 Registration date : 2012-09-14
| Subject: MFD Odometer software change - Miles to Km? Fri Sep 14, 2012 10:56 am | |
| Hi All, I’m a newbie here as I’ve just picked up my shiny new SWing last week. As I live in mainland Europe, I had a great ride over to run-in the engine on the 650 mile trip last Sunday. However, I’ve already got a technical question, which I hope has a simple fix:- The digital MFD odometer is presently showing in ‘Miles’, however, over here we use Kilometres and I’d like to change it over. [Naturally there’s no problem with the analogue Speedometer, marked in mph and kmph!] As the entire MFD is a digital display, it is not a simple software change….?? Any feedback on this would be greatly appreciated. Cheers, Steve |
rollsroyce250 Scooter Rider
Number of posts : 73 Location : Florida Points : 4395 Registration date : 2012-06-21
| Subject: Re: MFD Odometer software change - Miles to Km? Fri Sep 14, 2012 11:02 am | |
| You're out of luck. They're not reprogrammable. You need a new metric meter panel. |
joncallihan Silver Wing Guru
Number of posts : 1025 Age : 86 Location : Lafayette, Colorado, USA Points : 6715 Registration date : 2009-02-16
| Subject: Re: MFD Odometer software change - Miles to Km? Fri Sep 14, 2012 11:34 am | |
| Too bad the bike and car divisions are not more closely integrated. My S2000 car has a mile/km button for the entire cluster, both speed and distance.
:flower: |
Number of posts : 2085 Age : 71 Location : St.Pete.FL. Points : 7341 Registration date : 2010-02-03
| Subject: Re: MFD Odometer software change - Miles to Km? Fri Sep 14, 2012 3:59 pm | |
LTU-013 Scooter Rider
Number of posts : 33 Location : DOVER, MA Points : 4436 Registration date : 2012-04-04
| Subject: Re: MFD Odometer software change - Miles to Km? Fri Sep 14, 2012 10:14 pm | |
| Steve
I had same problem, just opposite way. I got my scooter from Canada and I'm in US. Canadian version has km/h
It was long discusion on the forum I was trying to find the way how to switch from km to miles I received a lot of help from SW gurus, unfortunately no luck
Both speedometer and speed sensor are the same part number in US and Canada, it means it is just software If you look at different angles at odometer - you can even see both words km and miles I was calling Honda headquarters in US, guys contacted few dealers in Canada, no luck - Honda doesn't want to tell how to switch between km/miles
Maybe we just have to send each other speedometers at winter time
Number of posts : 2940 Age : 75 Location : Winnsboro, Texas, U.S.A. Points : 8341 Registration date : 2010-02-17
| Subject: Re: MFD Odometer software change - Miles to Km? Fri Sep 14, 2012 10:35 pm | |
| Steve, welcome to the forum. As stated earlier, there was quite a discussion on speedometers. If you go to the search function and enter speedometer you can see it. As I recall, there were lots of comments, but no cure. Maybe someone has come up with a solution since then. If you find one, please let us know. |
Number of posts : 1099 Age : 70 Location : Cleveleys, Lancashire, England Points : 6317 Registration date : 2010-03-27
| Subject: Re: MFD Odometer software change - Miles to Km? Sat Sep 15, 2012 7:37 am | |
| Hello Steve,
hope you find a solution (not an expensive one) and post it on the forum.
Cheers, |
bikerboy Silver Wing Rider
Number of posts : 405 Age : 80 Location : Leyland England Points : 5154 Registration date : 2011-05-12
| Subject: Re: MFD Odometer software change - Miles to Km? Sat Sep 15, 2012 9:30 am | |
| Interesting that a European i.e. not UK model should be in mph, it seems that Honda do not tailor the machines to the market they are aimed at. Quite a surprise ! |
Number of posts : 3788 Age : 74 Location : Seaham, Co Durham, UK Points : 9440 Registration date : 2009-06-29
| Subject: Re: MFD Odometer software change - Miles to Km? Sat Sep 15, 2012 10:24 am | |
| Reading between the lines I think Steve bought his Silverwing in the UK. The mainland European models have the speedo in kilometres only - the UK ones have both MPH and KM marked on the dial as a rule (as he said). I have to overcome the problem when I move back - I'm not worried about the odometer in KMs but I don't think the bike will pass the MOT with only KMs on the speedo.....although I know the equivilents now. |
| Subject: Re: MFD Odometer software change - Miles to Km? Sat Sep 15, 2012 2:47 pm | |
| Lings do list a speedo head in mph but you will want to sit down and find an alternative when you read the price ---£782 !!!! |
| Subject: Re: MFD Odometer software change - Miles to Km? Sat Sep 15, 2012 5:14 pm | |
| Looked at a few MOT sites (including the official one) and no mention of an odometer anywhere. Speedos have to read both mph and kph but odometer cant be checked anyway. A friend of mine had a Mini Cooper, the first time I saw it was in 1974 and the odometer reading was 80000, today the odometer reading is 80000. But it passes every MOT without a problem.
Cheers, |
| Subject: Re: MFD Odometer software change - Miles to Km? Sun Sep 16, 2012 12:54 pm | |
Cheers, He was a lot more lucky than me -- I had a vanilla Mini of about the same vintage -- the odometer died at regular 2800 mile intervals. I can understand why he has not corrected the problem -- it seems that BMC started the assembly line with the speedo because it is so difficult to remove. As I remember, the entire induction system had to come off to gain access to the back of the cluster. :flower: |
| Subject: Re: MFD Odometer software change - Miles to Km? Mon Sep 17, 2012 4:39 am | |
| Hi again everyone, it seems I’ve hit on a well known subject and apologise that I did not fully research it on the site beforehand.
I must confess to being a little surprised (even slightly disappointed) that Honda can’t integrate this into the MFD as standard. Previously, I’ve just sold my Kawasaki ZX-10R and it had a digital display that could simply change the speedometer and odometer on the Mode Select button. I foolishly assumed this would be a ‘standard’ for all modern bikes, especially those with digital instrumentation (MFD) and from the flagship brand, Honda. Do they not realise people go touring in Europe or in the North American Continent?
Before I go any further, I should perhaps just add a little detail and clear up any confusion here concerning which type I actually have:- I am a U.K. citizen and now live and work in Switzerland. Before changing to the SWing, I did my research and was not surprised to see a price difference of about 20% between a U.K. or Swiss purchase. I also know that the Swiss import process is fairly straight-forward and can purchase the bike on a U.K. Personal Export Scheme and bought the bike VAT free (as Switzerland is not in the EU). The only definite requirements by the Swiss is to have a speedo in Kmph, headlights in the right direction (N/A on the SWing), and a EC Conformity Certificate. The only grey area is whether the odometer also must be in Km, but understand from others that this is not mandatory. Anyway, I’ll only find out for sure when the initial inspection is performed in the next couple of weeks. So I have a ‘U.K. Spec’ bike – on miles, in Europe!
I did go back to my U.K. Dealer last Saturday, and he said it would cost £740 to change the MFD for kilometres. As the installation is probably a nightmare, I shall keep my fingers firmly crossed that I don’t need to change it. On the other hand, if some enterprising software hacker could find a solution, I would be interested!
Anyway, having got that off my chest, I have absolutely no other gripe with my new pride and joy – a great ride!!
Hi Roger, in answer to your Post:-
My SilverWing is, of course, Silver.
The 10th Digit of the VIN is ‘7’, which I believe is the correct ‘year model’ when the SWing was last updated by Honda.
Number of posts : 4416 Age : 81 Location : damn near Philadelphia, PA Points : 10531 Registration date : 2009-06-12
| Subject: Re: MFD Odometer software change - Miles to Km? Mon Sep 17, 2012 9:44 am | |
| Changing the speedo / display is not all that difficult assuming that one is of the DIY persuasion. The big expense is in the cost of the part.
There is a way to change the display from Km to Mph but Honda won't part with that info.
But given that Swiss law is so finicky about the Km/Mph thing then perhaps there is some local gray market hacker who has figured out how to accomplish this. After all, the circuit board is the same for both versions of the MFD
Please keep us posted
| Subject: Re: MFD Odometer software change - Miles to Km? Tue Sep 18, 2012 6:43 am | |
| Without going into details, I have discovered that it is acceptable for me to 'stick' an overlay with MPH marked in the correct places on my speedo in order for it to satisfy the requirements of the MOT test......thank goodness! |
Dimond Silver Wing Expert
Number of posts : 540 Age : 79 Location : San Francisco Bay Area Points : 5316 Registration date : 2011-08-07
| Subject: Re: MFD Odometer software change - Miles to Km? Tue Sep 18, 2012 8:51 pm | |
| - MikeO wrote:
- ..... 'stick' an overlay with MPH marked in the correct places on my speedo ....
Nice! Simple! Thanks! |
| Subject: Re: MFD Odometer software change - Miles to Km? | |
