moosedaisy Scooter Rider
Number of posts : 84 Location : Charleston, SC Points : 4473 Registration date : 2012-05-22
matthew Touring Scooter Rider
Number of posts : 361 Location : near Santa Fe, NM Points : 5996 Registration date : 2008-12-24
| Subject: Re: Secret to getting the front wheel off? Mon Jun 11, 2012 8:03 pm | |
| On my '04, the axle comes out from the left side as you're working on the bike. It's the right side if you were sitting on the bike. You might try sticking a small metal something - screw driver or the like - thru the holes on the left side of the axle (as you're working on it), and hold it steady while turning the nut on the opposite side counter clockwise. Maybe that will provide the means to hold the axle itself still for nut removal. If this works, you should be able to relatively easily finesse the axle out. If it does start to come out, be careful to hold onto the wheel a bit so it doesn't just fall down when the axle is removed all the way. |
| Subject: Re: Secret to getting the front wheel off? Mon Jun 11, 2012 9:02 pm | |
| Thanks. I ended up tapping it out with a rubber hammer from the right side if you sitting on the bike. Once I put the new rubber on I'll clean it up and apply some grease. Hopefully this will make the process easier next time. |
Number of posts : 3783 Age : 74 Location : Seaham, Co Durham, UK Points : 9413 Registration date : 2009-06-29
| Subject: Re: Secret to getting the front wheel off? Tue Jun 12, 2012 5:31 am | |
| Many people swear by Copaslip for application in such situations - ordinary grease sometimes dries out and sticks the parts together, making the situation worse. |
| Subject: Re: Secret to getting the front wheel off? | |
