| Auxiliary Front Lights - Advice Wanted | |
+5MikeO DaveR honda_silver Hammy ehaughn 9 posters |
ehaughn Maxi-Scooter Rider
Number of posts : 131 Age : 55 Location : Norcross, GA Points : 5275 Registration date : 2010-06-13
| Subject: Auxiliary Front Lights - Advice Wanted Sun Sep 19, 2010 11:22 pm | |
| Hi All,
Now that I have the rear of the scooter lighted up nicely, I want to shift my focus on the front lights.
Curious on what folks have done to add more lighting to the front.
I see Dennis offers a bracket, would like to know how this is attached.
Ideally, I would like to use LED's. Hallogens get too hot, draw too much watts and burn out.
Thanks,
Erick |
Hammy Touring Scooter Rider
Number of posts : 362 Age : 47 Location : Philadelphia, PA Points : 5470 Registration date : 2010-05-22
| Subject: Re: Auxiliary Front Lights - Advice Wanted Sun Sep 19, 2010 11:42 pm | |
| I have a set of Vision-X solstice solos, 10 watts each. They're the same as the Denali lights sold on Twisted Throttle. I haven't yet mounted them on the Swing but a few of my buddies use the Denalis and they make you VERY conspicuous during the day and light up the road pretty well at night. |
Number of posts : 2453 Location : Georgetown, Tx Points : 8155 Registration date : 2008-12-23
| Subject: Re: Auxiliary Front Lights - Advice Wanted Mon Sep 20, 2010 12:04 am | |
| Subject: Re: Auxiliary Front Lights - Advice Wanted Mon Sep 20, 2010 3:09 pm | |
| honda_silver, how would you mount these lights?
| Subject: Re: Auxiliary Front Lights - Advice Wanted Mon Sep 20, 2010 6:50 pm | |
DaveR Silver Wing Rider
Number of posts : 440 Age : 87 Location : Scottsbluff, Nebraska U.S.A Points : 5990 Registration date : 2009-02-19
| Subject: Re: Auxiliary Front Lights - Advice Wanted Mon Sep 20, 2010 10:28 pm | |
| I have a "Dennis" mount on the front of my 2005. Equipped with "Burners" from Wal-Mart. They really work nice and light up the road. These are the silver ones and sell for about $20. I recommend them. If you see my pictures posted on this Forum you will see them. I really put them on for visibility from on-coming traffic. They can see me coming now! Old Dave |
| Subject: Re: Auxiliary Front Lights - Advice Wanted Mon Sep 20, 2010 10:41 pm | |
| How much was the "Dennis" mount?
I assume it attaches to the front 2 screws?
I would like to see detailed picture on how it attaches.
Erick |
Number of posts : 3788 Age : 74 Location : Seaham, Co Durham, UK Points : 9440 Registration date : 2009-06-29
| Subject: Re: Auxiliary Front Lights - Advice Wanted Tue Sep 21, 2010 4:57 am | |
Number of posts : 2778 Age : 73 Location : NE Oklahoma Points : 8881 Registration date : 2008-12-28
| Subject: Re: Auxiliary Front Lights - Advice Wanted Tue Sep 21, 2010 7:26 am | |
| Erick,
You need to try and do a little work yourself. We have a "SEARCH" button, I suggest you learn to use it from this point on.
DennisB, Site Administrator.
For those of you that do not know my product line...I try very hard to make it as easy as possible for the Silverwing owners to install my products. As for the light bar I supply the light bar, new screws, stand-off spacers for bikes 2002-2007, 2 pieces of black wiring covering each 6" long, and a small switch. As far as customer support, I provide illustrated installation instructions with all my products and other support in the form of schematic diagrams and online help.
EasyRider SilverWinger Scooter Rider
Number of posts : 30 Age : 75 Location : St. John's NL Canada Points : 4428 Registration date : 2012-04-09
| Subject: Re: Auxiliary Front Lights - Advice Wanted Thu May 24, 2012 9:04 pm | |
| I just installed an Admore mini using Dennis B's excellent perfect connector and also his front bar which I mounted and then installed a set of Denali D2 driving lights. The Denali harness is substantial and came with a series of male female connectors which were too big to route through the frame so I went nearby and under the floorboards to the frame exit and up through the rabbit hole and through the briar patch to Dennis's perfect wiring connector. The denali's can connect either low high beam or high only. The low high required a posi-tap to the high beam and looking at my manual wiring diagram with my specs and magnifying glass I was hoping to find an easy to posi-tap location which I thought about doing at the convenient to remove and replace headlight bulb location (anyone find your hand size doesn't fit the opening and mine aren't large (hands I mean) but I digress) I thought I could connect at the handlebar switch or the wiring to the easy access headlight but felt there was no way I was going to make a tight fit ...tighter...although right about then getting tight seemed the way to go Anyway as I already had all the left side, battery, Givi adjustable and misc other bits scattered around my shed I had a bright idea.................why not just pass go and hook up the high only..............its so much easie...cleaner that way. So I did and now I have low beam ...high beam...and flak tower search lights...........so the purpose of this diatribe is ...............has anyone installed highs only? And if so how does oncoming traffic feel about it? They are bright but that was at night and looking at my Swing in the shed she is at a higher elev than on road and since almost all of my driving is in day light I figured ....they are operational now so if Rudolph gets sick......I'm your man Santa. Plus people can;t say I'm not too bright anymore Easy |
Number of posts : 1099 Age : 70 Location : Cleveleys, Lancashire, England Points : 6317 Registration date : 2010-03-27
| Subject: Re: Auxiliary Front Lights - Advice Wanted Fri May 25, 2012 3:39 am | |
| I have a pair of this type. Mine has a dimmer (remote controlled) so you have daylight running lights (low) and very bright lights for night (high). There are about eight steps for the brightness.
http://www.ebay.co.uk/itm/20W-12V-1600LM-CREE-LED-Light-Rally-Ranger-4x4-Dirt-ATV-/250868768779?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3a68f1a00b#ht_4186wt_1051
Cheers, |
Daboo Super Scooter Rider
Number of posts : 271 Age : 71 Location : Seattle, WA Points : 5545 Registration date : 2009-12-08
| Subject: Re: Auxiliary Front Lights - Advice Wanted Fri May 25, 2012 11:05 am | |
| I have a pair of Model 30 LED lights mounted similar to the way Dennis designed the mount on a Silverwing. The lights use less than 10 watts each, but put out over 1500 lumens. ADVMonster.com sells brighter lights, but those are in a flood light pattern, not a spot light pattern. I think they would be difficult to use in traffic. Here's a picture from ADVMonster.com that gives an indication of just how tight and focused a beam they put out. Chris |
| Subject: Re: Auxiliary Front Lights - Advice Wanted Fri May 25, 2012 11:17 am | |
| Do you use high only or do you use a low high....sounds Hawaiian and with high on a two way road do you dim or are you high easy |
| Subject: Re: Auxiliary Front Lights - Advice Wanted Fri May 25, 2012 11:29 am | |
| I wired my LED lights up with a relay and independent of the lighting system so I wouldn't overtax the headlight circuit. So you could say I have a Low, High and whenever I want it, a driving light too. If you connect them to the High beam system, so they only come on with the high beams, then I'd think you'd be blinding the on coming traffic even if they don't flash their headlights at you. If you want to check how bright your lights are, go around a bend in the road with a police car coming the other way. If he makes his own red and blue light show immediately after, you'll know your lights are blinding. Chris Chris |
| Subject: Re: Auxiliary Front Lights - Advice Wanted Fri May 25, 2012 1:57 pm | |
| I tied mine into Dennis's switched power and located my Denali on off switch thru the vent in the dash so I have low, high and high Denali ...but i admit it.
They are bright though .............less so in daylight.................would like to hear if anyone has the D2 Denali on high only and the cage reactions on a two-way, street I mean. Easy |
| Subject: Re: Auxiliary Front Lights - Advice Wanted | |
