Latest topics | » Rear shock longevity by dovahkiin Today at 10:55 pm
» Latest Observations On My New To Me 2004 SW by GHM-PM Today at 7:40 am
» What did you do to your SW today. by Loosemarbles Tue Apr 16, 2024 4:26 pm
» YSS rear shocks by StuartBrown Tue Apr 16, 2024 1:36 pm
» New to Me Swing by Tbear Mon Apr 15, 2024 10:06 pm
» SOLD 2004 Honda Silver Wing for sale, tastefully modded SOLD by Rzor93 Sun Apr 14, 2024 2:29 pm
» peace, love and life by cello33 Fri Apr 12, 2024 6:35 pm
» Fork specs, please help before 9/4/2024 by Anders L Thu Apr 11, 2024 9:58 am
» Forgive My Rookie Questions by AldusFran Wed Apr 10, 2024 2:16 pm
» Greetings From 'Phoenix' by AldusFran Wed Apr 10, 2024 2:07 pm
| | Electrical problem: back half dead, blinkers really fast | |
craigory Maxi-Scooter Rider
Number of posts : 120 Age : 66 Location : California Points : 4856 Registration date : 2011-06-25
| Subject: Electrical problem: back half dead, blinkers really fast Mon Dec 12, 2011 12:24 am | |
| Went out to check something routine on my SWing and discovered it had developed some kind of electical problem overnight. Was working just fine when I parked it. Now all of the rear lighting is dead and my blinkers go really fast. I think the fast blinkers are probably due to the increased power going to the blinker relay because the rear signals are offline. More importantly, I haven't a clue what's going on with the back lighting. I checked all of the fuses and everything's good there. I'm hoping you guys have some ideas because I'm stranded until I fix it. |
| | | Winger61 Silver Wing Rider
Number of posts : 452 Age : 75 Location : Louth, Lincolnshire, UK Points : 5417 Registration date : 2010-10-15
| Subject: Re: Electrical problem: back half dead, blinkers really fast Mon Dec 12, 2011 12:39 am | |
| Could be one of the turn signal bulbs blown - that may cause the turn signals to flash quicker. Rear light bulbs could also have blown. |
| | | BlackFly Maxi-Scooter Rider
Number of posts : 151 Age : 45 Location : Germany Points : 5076 Registration date : 2010-11-20
| Subject: Re: Electrical problem: back half dead, blinkers really fast Mon Dec 12, 2011 4:14 am | |
| All bulbs are blown on the same time? Not impossible but i dont think so... How much ground wires are in that area for the rear lightning? I think it could be that the complete back don't have a correct ground connection. The first think i would measure is the continuity from the ground pole on the bulb to the frame... Other possibility: Are all the wires somewhere on the same connector? Possibly this connector is opened, therefore the second thing i would check: Is there 12V on the Bulbs (but measure directly against the frame, not again the other pole )? Both measurement are possibly without removal of any tupperware and should give you a startpoint for further troubleshooting |
| | | joncallihan Silver Wing Guru
Number of posts : 1025 Age : 86 Location : Lafayette, Colorado, USA Points : 6715 Registration date : 2009-02-16
| Subject: Re: Electrical problem: back half dead, blinkers really fast Mon Dec 12, 2011 10:17 am | |
| The multi pin plug behind the little door on the left side of the storage box probably managed to un-plug itself. :flower: |
Number of posts : 1995 Age : 76 Location : Huntsville, AL Points : 7665 Registration date : 2008-12-24
| Subject: Re: Electrical problem: back half dead, blinkers really fast Mon Dec 12, 2011 10:35 am | |
| Craig,
At the risk of stating the obvious - I'd start by checking some of your electrical modifications as noted in your signature.
Craig in California 2002 Dark Candy Red SilverWing Clearview windshield, Utopia backrest, Givi topcase, handlebar lifters, Kisan LED turn signals under the side mirrors, driving lights, leg wind deflectors, battery charging indicator, fuse block under seat to drive all electrical accessories, BackOff brake light modulator, additional lighting.
| | | Waspie Silver Wing Guru
Number of posts : 2392 Age : 72 Location : Portland, UK Points : 7931 Registration date : 2009-07-26
| Subject: Re: Electrical problem: back half dead, blinkers really fast Mon Dec 12, 2011 10:42 am | |
| - jdeereanton wrote:
- Craig,
Craig in California 2002 Dark Candy Red SilverWing Clearview windshield, Utopia backrest, Givi topcase, handlebar lifters, Kisan LED turn signals under the side mirrors, driving lights, leg wind deflectors, battery charging indicator, fuse block under seat to drive all electrical accessories, BackOff brake light modulator, additional lighting. Well spotted Dale - good call. |
| Subject: Re: Electrical problem: back half dead, blinkers really fast Mon Dec 12, 2011 11:35 pm | |
| I haven't had a moment to get behind that left-rear cover yet, but I think you guys probably have this nailed. Blackfly touched on it, joncallihan reinforced it, and jdeereanton nailed it to the wall. All of the rear lighting is connected through a single connector behind the left-rear cover. The BackOff brake light modulator is inline for the inbound and outbound connectors. I'm guessing that either one of the connectors worked loose, or the BackOff simply backed off and will now need to be replaced. As joncallihan pointed out, that connector is normally accessible throught the hatch in the storage box, but with the BackOff unit there it is pretty much impossible to get to anything through there. I'll have to take off the left-rear cover to get to it, but that's pretty easy. I plan to get to it tomorrow and I'll let everyone know how it works out. |
| Subject: Re: Electrical problem: back half dead, blinkers really fast Tue Dec 13, 2011 3:20 pm | |
| Yep. You guys had it. The honda connector from the front slipped out of the BackOff connector. Pushed them back together and now everybody's happy. Thanks all who replied to my post! |
| Subject: Re: Electrical problem: back half dead, blinkers really fast Tue Dec 13, 2011 3:32 pm | |
| Glad you had a result and it wasn't that traumatic. |
| | | Sponsored content
| Subject: Re: Electrical problem: back half dead, blinkers really fast | |
