| hand made clutch tool | |
john123 Maxi-Scooter Rider
Number of posts : 133 Age : 75 Location : Santa Barbara California Points : 5329 Registration date : 2010-02-21
| Subject: hand made clutch tool Sun Aug 28, 2011 12:02 pm | |
| A few years ago I read someone's article about making a tool made out of a piece of wood and two bolts that were to be placed into the clutch area and it would hold it so you could remove or install the large nut, and be able to replace the pins or sliders and belt. Any one help me with this? |
redeye Maxi-Scooter Rider
Number of posts : 163 Location : Fannin County, Georgia Points : 5093 Registration date : 2010-10-13
| Subject: Re: hand made clutch tool Sun Aug 28, 2011 12:12 pm | |
| This may be the item you're after.
http://www.leroybeal.net/motorcycles/silverwing/articles/drivepulleytool/drivepulleytool.html
I was looking at this a few days ago. |
| Subject: Yup Yup Sun Aug 28, 2011 12:21 pm | |
| Fantastic. That is exactelly what I was refering to. You are the best! |
| Subject: Re: hand made clutch tool Sun Aug 28, 2011 12:56 pm | |
| Goodness, you made my day. Glad that was it. My Silver Wing's odo is roughly 14,500 miles, so belt replacement time will soon arrive. |
goldwinger Scooter Rider
Number of posts : 75 Age : 70 Location : Canvey Island, Essex, UK Points : 4763 Registration date : 2011-06-15
| Subject: Re: hand made clutch tool Sun Aug 28, 2011 1:31 pm | |
| I copied that idea a few weeks ago and it works great!!!
Ian |
Number of posts : 2387 Location : Winnipeg Points : 7668 Registration date : 2010-05-02
| Subject: Re: hand made clutch tool Sun Aug 28, 2011 1:55 pm | |
| Subject: Re: hand made clutch tool Sun Aug 28, 2011 3:22 pm | |
| Very true, well spotted!!! But, actually, you can change the clutch without a puller.
Ian |
| Subject: Re: hand made clutch tool Sun Aug 28, 2011 6:12 pm | |
| Subject: Re: hand made clutch tool Sun Aug 28, 2011 10:56 pm | |
| - bigbird wrote:
- goldwinger wrote:
- Very true, well spotted!!! But, actually, you can change the clutch without a puller. Ian
Do you know something the service manual doesn't? Actually, all you have to do to remove the driven pulley / clutch is to lock up the rear brake while you loosen the 22 mm hub nut. It's only torqued to 45 lbs ft, so it's not at all difficult. No special tools needed. Tim |
| Subject: Re: hand made clutch tool Mon Aug 29, 2011 1:02 am | |
| Subject: Re: hand made clutch tool Mon Aug 29, 2011 10:22 am | |
| I used a short piece of left over oak hardwood flooring to make the same variator tool noted above. |
| Subject: Re: hand made clutch tool Mon Aug 29, 2011 10:39 am | |
| bigbird, when I undid the main nut with an air wrench (with the handbrake on and a cable tie on the rear brake lever) the clutch came off quite easily, with just a little help from 2 broad blade screwdrivers to lever behind. I only attempted it because I had a 2/3 leg puller but it wouldn't fit, so I tried to ease it off with the screwdrivers and it came off without much effort. As my bike is 2001, I expected it to be a real problem, so hopefully they are all that easy?
Ian
| Subject: Re: hand made clutch tool Mon Aug 29, 2011 11:36 am | |
| Subject: Re: hand made clutch tool Mon Aug 29, 2011 1:25 pm | |
| My pleasure Terry, glad I can be of help to you for a change.
Ian |
derekg Scooter Rider
Number of posts : 79 Age : 77 Location : Stirling Scotland Points : 5054 Registration date : 2010-09-02
| Subject: Re: hand made clutch tool Tue Aug 06, 2013 6:31 pm | |
| Excuse if this is a daft question.... Nearing the mileage where I will renew the drive belt so about to make myself a tool as covered above.(thanks to the member who posted) Now did I read someplace that the "nut" I need to remove requires to be turned in the "wrong/other" direction?...ie get it off by turning it to the right?...or is first stage senility setting in. ...would rather ask a "daft" question than end up over tightening a nut and damaging the thread...Already over tightened and sheared off one of the 5 bolts holding the casing on ... leaving me with a problem... Thanks for any advice... |
| Subject: Re: hand made clutch tool Tue Aug 06, 2013 10:01 pm | |
| Lefty loosey, rightey tightey |
Scoundrel Maxi-Scooter Rider
Number of posts : 107 Location : Western Washington State, US Points : 4122 Registration date : 2013-04-15
| Subject: Re: hand made clutch tool Wed Aug 07, 2013 12:50 am | |
| I have not yet run across a reverse threaded bolt on a Silverwing, and I've removed both pulleys and replaced the clutch. |
| Subject: Re: hand made clutch tool | |
