Honda Silver Wing Forum
» Mud Flap on front wheel
by RArch Today at 12:23 am
» Clock resets
by Straight8 Today at 12:16 am
» I did not Die!
by Straight8 Today at 12:00 am
» Adjustable Hand Brake Levers
by Fazli Yesterday at 10:48 pm
» Handguards
by MarkB Yesterday at 9:47 pm
» Steve involved in motorcycle wreck
by BoxcarMark Yesterday at 9:38 pm
» Anyone building/selling side mounts/rack
by MarkB Yesterday at 9:15 pm
» Riding Technique for Unpaved Loose Gravel and Rocky Roads?
by robert Yesterday at 8:25 pm
» How do you learn how to lean?
by trouble1100 Yesterday at 7:11 pm
» Now that's a bike!
by dspevack Yesterday at 6:41 pm
» Do you use (or your dealer) tire bead sealant?
by Dimond Yesterday at 5:17 pm
» V Belt noise?
by redeye Yesterday at 10:05 am
February 2012
SunMonTueWedThuFriSat
   1234
567891011
12131415161718
19202122232425
26272829
CalendarCalendar
 waxes and/or polishes
Goto page : 1, 2  Next
skydad99
Number of posts: 43
Registration date: 2009-07-19
PostSubject: Re: waxes and/or polishes   Wed Jul 22, 2009 3:41 pm
DennisB wrote:
skydad99 wrote:
"Are you sure its made of Lexan? My Givi is made of Plexiglas. Lexan also scratches much easier than plexiglas, but is more impact resistant."
Lexan (polycarbonate) is approved for use as a windshield on motorcycles by the DOT.
Plexiglas (acrylic) is not DOT appoved. I shatters to easy when hit buy rocks and other things coming off the road.
"Polycarbonate is a DOT approved material for making windshields; normal acrylic is not. Some states require DOT approved windshields, and therefore in these states a normal acrylic windshield is actually illegal, however these laws are rarely enforced. Normal acrylic can be shattered by an impact from a rock moving at speeds as low as 15mph. "
http://www.calsci.com/motorcycleinfo/Fairing.html
My Givi windshield is made of LEXAN and so is my helmet screen.
That's a pretty interesting site. I note that a special high cost acrylic called Impact Modified Acrylic is available. This form of acrylic is DOT approved for windshields. This is not Lexan. I know for a fact that the Clearview Windshield is made with this, and I bet the Givi I have is also. If made by Dupont, it would have the plexiglas name on it, which it does. I also noticed that Lexan is made by GE. That's interesting. Regadless, that site is being saved because it has all kind of good information on it. Thanks for the link, Dennis.
Number of posts: 2300
Registration date: 2008-12-28
PostSubject: Re: waxes and/or polishes   Wed Jul 22, 2009 3:46 pm
Your right...it does say plexiglas GS
Thanks for the information.
PostSubject: Re: waxes and/or polishes   Wed Jul 22, 2009 4:04 pm
OK, GIVI Windshields (plexiglass GS) Cleaning, Wink
"Unfortunately Windex cannot clean everything, nor should it. Most glass cleaning products contain ammonia or alcohol that, while harmless on glass, will damage your plexiglass. Your first step in cleaning plexiglass it to break the habit of reaching for the glass cleaner. Harsh chemicals will alter plexiglass and cause it to become opaque, thus frustrating any hope of keeping the plexiglass as clean and transparent as possible.
If your plexiglass has been installed or provided by a manufacturer you may want to check and see if the manufacturer suggests any specialized cleaning products. If possible, follow the directions for cleaning and maintenance provided by your manufacturer.
If you are hoping to clean your plexiglass with household items you can follow this procedure:
Begin by blowing the dirt and dust off the surface of the plexiglass. Avoid using your hand or a dry cloth to remove dirt; you might rub the dirt in harder and accidentally scratch the surface of the plexiglass.
Once you have air-removed as much dirt as possible wet down the surface. It is best to create a layer of running water over the plexiglass so the dirt will be able to just float off. Avoid spraying the plexiglass with too much force, otherwise the surface could become chipped. (An example would be using a hose and pressure nozzle on the plexiglass. Such force is not necessary.)
Using a soft, lint-free cloth, wash the surface with warm soapy water. You can use liquid dish soap or gentle, non-abrasive liquid dishwashing soap. Rinse and dry the plexiglass with another soft, lint-free cloth. Don't allow the plexiglass to air dry, otherwise water spots will be left behind. Also, avoid using paper towels in the cleaning process because even they are abrasive enough to cause small scratches and eventual opaqueness.
Clean your plexiglass as often as is needed. By not allowing too much dirt and dust to build up, you will avoid the need to clean and scrub too harshly later."
mr fish
Number of posts: 274
Registration date: 2009-03-23
PostSubject: Re: waxes and/or polishes   Thu Jul 23, 2009 12:57 am
Just another housewives tip cheers if you have a screen full of bugs place some damp kitchen towels over it for about 10 minutes and they simply wipe off
Number of posts: 1688
Registration date: 2008-12-24
PostSubject: Re: waxes and/or polishes   Thu Jul 23, 2009 2:15 am
I am astonished at the amount of attention this topic gets on all forums.
We have stock windscreens on our SilverWings and other than the use of Plexus before we head out on a big ride we regularly use Windex and a cotton towel to clean our windscreens. (We often ride on bikes that haven't been washed in a month!) While on the road we use the prepackaged wipes. This has been our modus operendi since August 2003 when we first got our Reflexes. No cloudy windscreens, no micro scratches resulting in crashes due to sunbursts of light.
I continue to be amazed at the obsession with cleaning the windscreen. Just to ease the mind of those who don't have a formalized ritual for cleaning the windscreen - it doesn't matter. Just don't use a brillo pad, comet or sandpaper and you should be fine. Cool
_________________
Dale
Huntsville, AL
2 x 2005 - Hers & His
Boots, socks, underwear, pants, t-shirt, jacket, gloves, & helmet.
http://www.youtube.com/user/jdeereanton
Riding on "Just Basic Shocks" - My shocks, while completely functional, have never even been nominated for an award.
PostSubject: Re: waxes and/or polishes   Thu Jul 23, 2009 3:54 am
This is a forum and like all forums many topics will be talked about and alot of information and ideas will shared amoung it's members. No topic will just end, it just goes on. So if you have a better way to keep your scooters windshield sparkling clean or have a product that you like to use, please join in.
Always remember, it would not be a forum without your input......
DennisB sunny
kawibiker
Number of posts: 11
Registration date: 2009-06-27
PostSubject: Re: waxes and/or polishes   Thu Jul 23, 2009 5:32 am
Does anyone use Can-Do, the spray cleaner wax on their stock SW shield?
I have used it on previous bikes, no problem, but will use water till I hear this is ok.
PostSubject: Re: waxes and/or polishes   Thu Jul 23, 2009 7:11 am
I'm not saying don't contribute or that it should end, or even that no one should be interested - just that I am amazed this is such a hot topic. And, also that I am surprised that there are so many ways that it should not be done that are endorsed as the only way it should be done. Or that our windscreens are apparently several different compositions of plastic.
Please post on. May be I'm just bored at work today...
_________________
Dale
Huntsville, AL
skydad99
Number of posts: 43
PostSubject: Re: waxes and/or polishes   Thu Jul 23, 2009 7:29 am
I have never heard of Can-Do, but I don't think any wax type stuff would hurt your windshield. I know Johnson's Pledge works great for cleaning & protecting it.
mr fish
PostSubject: Re: waxes and/or polishes   Thu Jul 23, 2009 8:55 am
So mine made of see through plastic and should not be cleaned with rocks or crocadile teeth
lol!
PostSubject: Re: waxes and/or polishes   Thu Jul 23, 2009 10:02 am
You're all over it. Although powdered crocodile teeth made a real fine dust that is good for removing the scratches.
_________________
Dale
Huntsville, AL
PostSubject: Re: waxes and/or polishes   Thu Jul 23, 2009 10:07 am
Crocadile teeth!!!
Is that just teeth and not the snappers? Pretty darn scarry way to get the windsield clean.
mr fish
PostSubject: Re: waxes and/or polishes   Thu Jul 23, 2009 10:12 am
leave them in the croc that way you can get a better grip then throw back in the water
PostSubject: Re: waxes and/or polishes   Thu Jul 23, 2009 10:38 am
Hy John,
Don't throw them back....recycle'em, I'm thinken a nice pair of boots! YEA! cheers
skydad99
Number of posts: 43
PostSubject: Re: waxes and/or polishes   Thu Jul 23, 2009 11:20 am
I imagine eating crocodile would be about like eating alligator. Use all of it, not just the skin.
mr fish
PostSubject: Re: waxes and/or polishes   Thu Jul 23, 2009 1:45 pm
No just wrestle them
tvpRich
Number of posts: 19
Registration date: 2009-08-12
PostSubject: Re: waxes and/or polishes   Wed Aug 19, 2009 10:15 pm
I used FW1 from www.fastwax.com on my Swing including the windshield. Also WD40 seems to work good on all other rubber & plastic parts for me.
http://www.tvpstudiosburbank.com/
Number of posts: 1480
Registration date: 2009-07-26
PostSubject: Re: waxes and/or polishes   Mon Aug 24, 2009 12:39 pm
Ahhhhhhhhhhh WD40 on rubber - Nooooooooooooooo
Over a period of time WD40 is known to cause perishing of rubber parts.
Learned the hard way in the aviation industry. affraid
http://www.facebook.com/Waspie41
tvpRich
Number of posts: 19
PostSubject: Re: waxes and/or polishes   Mon Aug 24, 2009 3:21 pm
Hi.
Well I've heard of that too, but I guess I never owned any rubber parts long enough to see the perishing... What might you suggest for black rubber & plastic to give it that "Dark Shiny Black Look" that stays for at least a week ?
Rich
Number of posts: 412
Registration date: 2009-07-17
PostSubject: Re: waxes and/or polishes   Mon Aug 24, 2009 3:44 pm
Been using Lemon Pledge, yep, the furniture polish, on my bikes for years. Used it for a lot of years on aircraft windshields. I liked it on float planes because it make the water bead up and blow off better. Cheap and works on the plastic and the windshield. Did I say cheap too?
PostSubject: Re: waxes and/or polishes   Tue Aug 25, 2009 2:31 am
tvpRich wrote:
Hi.
Rich
In the UK I use a product called 'Amour All'. restores plastics and puts a nice waterproof coating on it too.
Or you could go the cheap route and use domestic household polish!!!!!!!! Johnsons Pledge or the like as said above!!!!!
PostSubject: Re: waxes and/or polishes   Tue Aug 25, 2009 2:34 am
As an aside. I was in my local dealer when an Arai helmet Rep was visiting.
A customer asked what would the Rep reccommend to clean his helmets visor.
What do you want? the rep replied, the company answer or my personal advice.
Both was the reply.
Company answer was, buy our Arai visor cleaner at mega bucks
OR
Pledge!!!! Every home has some!!
Says it all really! Rolling Eyes
regors
Number of posts: 27
Registration date: 2009-02-15
PostSubject: Re: waxes and/or polishes   Sun Sep 27, 2009 5:20 am
If you use "Amour All" on your seat you will find yourself sliding forward, if you use it on your tires you might be in for a surprise.
PostSubject: Re: waxes and/or polishes   Sun Sep 27, 2009 12:06 pm
Agree but it does state on the 'directions fore use' where it can and cann not be used.
Side walls of tyres, OK tires!!!! are ok but the tread a NO - NO.
Still can't beat domstic furniture polish though.
tankyuong
Number of posts: 372
Registration date: 2009-07-11
PostSubject: Re: waxes and/or polishes   Sun Sep 27, 2009 7:57 pm
303 aerospace protectant is the best hands down, kind of hard to find though.....
PostSubject: Re: waxes and/or polishes   Sun Sep 27, 2009 9:40 pm
And I bet impossible to source in the UK!!
Number of posts: 1244
Registration date: 2009-01-10
PostSubject: Re: waxes and/or polishes   Mon Sep 28, 2009 11:30 am
I think this is the same product... and it seems to be available there for yall.
http://www.cleanyourcar.co.uk/interior/303-aerospace-protectant/prod_366.html
Gary
PostSubject: Re: waxes and/or polishes   Mon Sep 28, 2009 12:29 pm
Opalsboy, many thanks for the link.
stevec
Number of posts: 27
Registration date: 2010-07-18
PostSubject: Re: waxes and/or polishes   Thu Jul 22, 2010 6:18 am
What the protectent to used on all the black tupperware?
stevec
Number of posts: 27
PostSubject: Re: waxes and/or polishes   Thu Jul 22, 2010 6:24 am
i meant what the best protectent to use on all the black tupperware
Page 1 of 2Goto page : 1, 2  Next
» waxes and/or polishes
» Teflon and anti-rust
» Triplewax Fast Wax
» How to polish aluminum wheels
» Best Car Wash and Wax for Shimmering White paint?
Honda Silver Wing Forum :: Honda Silver Wing :: Maintenance Tips and Hints-
