| Author | Message |
Ishkatan Maxi-Scooter Rider
Number of posts: 128 Age: 57 Location: Monrovia, Md Points: 706 Registration date: 2010-11-16
 | Subject: Shocks squeak Wed Jun 15, 2011 7:30 am | |
| My Rear Shocks squeak when I bounce on the bike. javascript:emoticonp('  ') Don't ask why I am bouncing on the bike ... or use your imagination... javascript:emoticonp('  ') Anyway, I am not aware of the shocks not working right and don't see fluid leaking, just hear the squeak. Can I put some oil on upper rod to lube them? Would that hurt the seals? Other suggestions? BTW, my 1998 Grand Marquis front shocks also squeak when I bounce on the hood. (Again, don't ask why but imagine ....). The Mr. Tire shop said $$$ to replace.... but when I asked if they actually needed to be replaced they said "No, they work fine but will fail eventually"... Well of course they will with enough miles and squeaks... So I driving riding two vehicles with squeaky shocks I don't want to damage but really want to oil or grease. javascript:emoticonp('  ') |
Cosmic_Jumper Touring Scooter Rider
Number of posts: 303 Location: damn near Philadelphia, PA Points: 1448 Registration date: 2009-06-12
 | Subject: Re: Shocks squeak Wed Jun 15, 2011 8:11 am | |
| Adam,
IMHO They all squeak. More than likely the noise is coming from the spring moving slightly where it seats on both the upper (shock cap) & lower shock body / spring adjuster.
You might try squirting some 'Blaster' Dry Lube at those locations. Though you'll be hard-pressed to access the upper shock cap.
BTW you'll need that Blaster Dry Lube eventually when you decide to upgrade to Dr Pulley variator Sliders. Home Depot has it for ~$5.
dspevack Site Admin
Number of posts: 1146 Age: 47 Location: Miami, FL Points: 2588 Registration date: 2008-12-27
 | Subject: Re: Shocks squeak Wed Jun 15, 2011 9:03 am | |
| Squeaking shocks are proof that you are "bouncing" correctly, I would imagine... _________________ I ride on two wheels cause I feel very unsafe on one wheel.Dan in Miami. The king of custom! Check out my bike mods hereReality is irrelevant. Its perception that counts. Control people's perceptions, and you control their reality. |
Darkheart Scooter Rider
Number of posts: 5 Points: 375 Registration date: 2011-05-20
 | Subject: Re: Shocks squeak Wed Jun 15, 2011 10:41 am | |
| BTW the squeak on your cage is most likely ball joints that need grease. shoot so WD_40 on them see if they stop. |
redeye Maxi-Scooter Rider
Number of posts: 151 Age: 51 Location: Maryland Points: 750 Registration date: 2010-10-13
MaxB Touring Scooter Rider
Number of posts: 302 Age: 60 Location: Indiana Points: 1321 Registration date: 2009-10-06
 | Subject: Re: Shocks squeak Wed Jun 15, 2011 6:13 pm | |
| Try lubing the bushings on the top , WAAAY up under the tupperware. and the ones inside the clevis at the bottom.
Mine squeek every couple of yrs/ ride in a lot of rain/
MaxB (who squeeked all the way accross Wyoming) |
honda_silver Site Admin
Number of posts: 2258 Age: 51 Location: Georgetown, Tx Points: 3605 Registration date: 2008-12-23
 | Subject: Re: Shocks squeak Wed Jun 15, 2011 6:36 pm | |
| | Ishkatan wrote: | | Other suggestions? |
After you clean/lube the upper rod, I use the reflective Hippo fork protectors ( http://www.hippohands.com/Products%20Description.htm ) or something equivalent around my shocks greatly reducing the dirt/grit on the rod. I can easily separate the velcro then remove and clean the dirt off the protector._________________ Bill - Georgetown TX 07 Silver Wing ABS Clearview w/vent, Givi E96/TB19/E52 with Admore Lighting, Alaskan Leather, Wrist Rests, 3M Solas tape, K&N air, Hyperpro spring, Grip Puppies, Airhawk, Utopia backrest, Stebel, Apexcone HIDs, StingerZ LEDs (w/Backoff WigWag), Knight Rider Sequential LED, NGK Iridium, Power Commander III, Manic Salamander, Saeng mirrors, Garmin Zumo 660, Dark-Side Sumitomo Tire  |
john grinsel Silver Wing Expert
Number of posts: 530 Points: 1603 Registration date: 2009-08-18
 | Subject: Re: Shocks squeak Thu Jun 16, 2011 5:17 am | |
| The WD 40 is the fix-----sometime a little compressed air and/or brush treatment- Noise spring rubbing on plastic.
John Grinsel |
joncallihan Silver Wing Expert
Number of posts: 786 Age: 74 Location: Lafayette, Colorado, USA Points: 2109 Registration date: 2009-02-16
 | Subject: Re: Shocks squeak Thu Jun 16, 2011 7:03 am | |
| | john grinsel wrote: | The WD 40 is the fix-----sometime a little compressed air and/or brush treatment- Noise spring rubbing on plastic.
John Grinsel | WD 40 will do a pretty good job of dissolving the plastic, I'd use silicone spray instead. IMO
Jon |
eddy Maxi-Scooter Rider
Number of posts: 130 Age: 61 Location: Europe Flanders. Points: 1055 Registration date: 2009-11-27
 | Subject: Re: Shocks squeak Thu Jun 16, 2011 7:58 am | |
| wd40 dissolving the plastic ? Facts or fantasy??
I used it for years...
Never noticed a problem.
Eddy |
 | Subject: Re: Shocks squeak Thu Jun 16, 2011 8:18 am | |
| This is based on personal experience with sliding screen rollers. I have no idea what kind of plastic they were.
Jon |
 | Subject: Re: Shocks squeak Fri Jun 17, 2011 6:44 am | |
| Two materials to avoid in case of spray/lub. , based on petrol... Like wd40 and many others.
Polystyrene ; The very light insulation material. Like for food containers
Polycarbonate ; Transparent hard plastic like for greenhouses. Also windshields for mc ...
Eddy |
trouble1100 Maxi-Scooter Rider
Number of posts: 176 Age: 55 Location: Plum Pa Points: 1012 Registration date: 2010-04-30
 | Subject: Re: Shocks squeak Thu Oct 06, 2011 2:44 am | |
| I tried the WD-40 route and it helped, but some dripped over time and left dark streaks on the lower part of the rear shocks. Now the squeak is back, both on the bike and even louder on the car.
Time to search for a vendor of PB Blaster Dry Lube in my area. Or good old fashioned gear oil or grease? |
 | Subject: Re: Shocks squeak Thu Oct 06, 2011 4:29 am | |
| | Ishkatan wrote: | | Time to search for a vendor of PB Blaster Dry Lube in my area. |
I found the Dry Lube at Home Depot. |
