| handle bar shaking when hands-off | |
+4DennisB rogerscoot MikeO ron1999 8 posters |
ron1999 Scooter Rider
Number of posts : 36 Location : Falls Church VA Points : 4847 Registration date : 2011-02-12
| Subject: handle bar shaking when hands-off Sun Apr 17, 2011 5:14 am | |
| Hi All great to see a dedicated Silverwing forum (i call mine Honda VFA - Very Fast Armchair) its a 2006 400cc Honda Silverwing. im its second owner, bought it a month ago with 26K km on it. as soon as i got it i replaced the original IRC tires with a pair of Pirelli Diablo Scooter.
and now for the question -
while riding and handling - it seems to be fine, everything is ok and no shakes / rattles or anything is felt, yet, when going 30-40 km/h, if i leave the handle bars, it starts to get wobbly and shake. is this normal? should i be concerned about it?
thanks
Ron.
Number of posts : 3783 Age : 74 Location : Seaham, Co Durham, UK Points : 9413 Registration date : 2009-06-29
| Subject: Re: handle bar shaking when hands-off Sun Apr 17, 2011 6:03 am | |
| Hello, Ron, and welcome! Love the 'VFA' bit. Hands-off wobble seems to be something that some bikes suffer from and others not. If you do a SEARCH you'll find stuff about it and no doubt members will pass on their solutions in due course. I hope you've found DennisB's shop - lots of superb custom-made goodies (no gimics, though) for Swingers to buy and worth every cent/penny/shekel. |
rogerscoot Scooter Rider
Number of posts : 73 Location : Brinsley, UK Points : 4910 Registration date : 2011-01-05
| Subject: Re: handle bar shaking when hands-off Sun Apr 17, 2011 7:21 am | |
| Hi Ron I had this many years ago on my motorcycle. It happened at 28-30 mph which was very annoying and only happened with one brand of tyre. At that time it was thought to be because of the lack of a straight groove down the centre of the front tyre. Check your tyre pressures and front wheel bearings. Maybe try a little extra pressure in the front tyre to see if it makes a difference |
Number of posts : 2778 Age : 73 Location : NE Oklahoma Points : 8859 Registration date : 2008-12-28
| Subject: Re: handle bar shaking when hands-off Sun Apr 17, 2011 8:26 am | |
| Hi Ron, My best guess would be tire being a little out of balance or wheel bearings starting to go bad.
Well there you have it. My best guess. |
Number of posts : 341 Location : Surprise, AZ. Points : 5550 Registration date : 2010-04-30
| Subject: Re: handle bar shaking when hands-off Sun Apr 17, 2011 12:50 pm | |
| Honda suggests 1. Wheel bearing play 2. Bent rim 3. Improper installation of the wheel 4. Swing arm pivot bearing wear 5. Bent frame.
You may have a loose steering stem bearing. Adjustment on a few previous bikes corrected the headshake problem. I owed a GL1500 that was loose enough to feel the play while holding the front brake and rocking, or compressing the front forks. Take a look at the video below for a simple test and the fix for the wobble.
https://www.facebook.com/video/video.php?v=1401175502815
The adjustment for the Silverwing can be found in the repair manual section 14, page 30 in the FSC600 Service Manual. Honda suggests using a spring scale to test the preload but I found the test in the video is sufficient for diagnoses.
billc. Maxi-Scooter Rider
Number of posts : 189 Age : 75 Location : Atlanta, Ga. Points : 5375 Registration date : 2010-02-19
| Subject: Re: handle bar shaking when hands-off Sun Apr 17, 2011 1:28 pm | |
| That is very useful information....THANKS for posting this...billc. |
| Subject: Re: handle bar shaking when hands-off Sun Apr 17, 2011 5:32 pm | |
| Hi Guys, thank you all for the info, the movie on facebook really helps - i will check this tomorrow, as i thought that this is really nothing, but it may be something worth fixing.
prior buying my Swing, i took it for a complete check at a special shop who expert in these things - they say that the Swing head bearing has a little "step" in the middle of its movement. Could it be related? |
| Subject: Re: handle bar shaking when hands-off Sun Apr 17, 2011 9:15 pm | |
| A little step-----often problem years ago with Japanese bikes= notch as you turn bars side to side with wheel off ground.
Makes riding real slow difficult---could be part of your head shake problem, but check tires/wheels/load in top box also/swing arm bearings.
Are wheels on right?
John Grinsel |
Sweendog Maxi-Scooter Rider
Number of posts : 154 Location : South New Jersey Points : 5541 Registration date : 2009-07-12
| Subject: Re: handle bar shaking when hands-off Sun Apr 17, 2011 10:31 pm | |
| Great video explaining how to check and adjust the stem bearing! Nifty skull-motif headlight on that V-Max too!
Those bikes are the motorcycle equivalent of a GTO or Charger or something. -All muscle, crap for suspension/handling performance. =) |
| Subject: Re: handle bar shaking when hands-off | |
