| Author | Message |
wingmann Scooter Rider
Number of posts: 36 Age: 55 Location: HAM lake MN. USA Points: 699 Registration date: 2010-08-22
 | Subject: Protecting the radiator Sun Mar 06, 2011 11:16 am | |
| Has anyone ever put some aluminum window screen between the radiator and the black plastic louvers on there Silverwing to help stop rocks that get kicked up from damaging the radiator and stop bugs from plugging the radiator and stop the floting suff from the cotton wood trees and so on from plugging the air flow on the radiator . If anyone has done this how did it afect your coolent temp . Years ago I had the old 1983 model Honda Silverwing that I put the window screen on the radiator and even on hot days I never had any over heating . I have all so done this on all of my cars and trucks but they have big radiators . The screen is alot easyer to clean then the radiator. |
DickO Silver Wing Rider
Number of posts: 480 Age: 67 Location: Harveyville, Kansas (SW of Topeka) Points: 1776 Registration date: 2008-12-23
 | Subject: Re: Protecting the radiator Sun Mar 06, 2011 5:48 pm | |
| Hi "wingman", Don't know about all that pesky cottonwood stuff but there have been 2 or 3 others on this site who have put fender extenders on to help mitigate any other possible damage. Think there are even some pics someplace (even good ol' John Grinsel had some). As to the screen, can't see where that should be much of a problem. I would think the SWing should be able to handle it since it cools so well to begin with. At least that's my two cents worth.
By the way... if you come up with an easy screen installation method, let us know. Sounds like a good idea; just don't know how much trouble it would be. |
 | Subject: Re: Protecting the radiator Sun Mar 06, 2011 7:41 pm | |
| I am not only thinking of the rocks from the front wheel but I am thinking of the rocks that fly up from the cars and trucks in front of my silverwing . A lot of us have had rocks hit are car windshield from the car a head of us and they hit hard . So I am thinking of saving my silverwing radiator before it happens . Sometimes its a long ways to push the silverwing home. |
exavid Silver Wing Rider
Number of posts: 412 Age: 69 Location: Medford, Oregon Points: 1481 Registration date: 2009-07-17
 | Subject: Re: Protecting the radiator Sun Mar 06, 2011 8:25 pm | |
| Probably wouldn't hurt anything but I've never heard of a SW getting any road damage to it's radiator. My Goldwings never did either for that matter and their radiators are about as much at risk as the SW's. Might be a bit of a solution looking for a problem. |
honda_silver Site Admin
Number of posts: 2258 Age: 51 Location: Georgetown, Tx Points: 3605 Registration date: 2008-12-23
 | Subject: Re: Protecting the radiator Mon Mar 07, 2011 8:09 am | |
| | exavid wrote: | | Probably wouldn't hurt anything but I've never heard of a SW getting any road damage to it's radiator. |
I though I remember reading one member of one of the forums had to replace their radiator due to damage.
Would a screen or a longer mudflap helped ... I do not believer there was enough details._________________ Bill - Georgetown TX 07 Silver Wing ABS Clearview w/vent, Givi E96/TB19/E52 with Admore Lighting, Alaskan Leather, Wrist Rests, 3M Solas tape, K&N air, Hyperpro spring, Grip Puppies, Airhawk, Utopia backrest, Stebel, Apexcone HIDs, StingerZ LEDs (w/Backoff WigWag), Knight Rider Sequential LED, NGK Iridium, Power Commander III, Manic Salamander, Saeng mirrors, Garmin Zumo 660, Dark-Side Sumitomo Tire  |
tfrench40 Scooter Rider
Number of posts: 8 Age: 55 Location: Eastern Shore of Maryland USA Points: 586 Registration date: 2010-10-31
 | Subject: Re: Protecting the radiator Wed Mar 09, 2011 10:45 pm | |
| I have been thinking about the screen idea as well, My thoughts are a small tube of RTV adhesive and run a bead around the perimeter of the radiator opening as well as on the cross piece then simply pressing the screen on to / in to the bead of RTV. I am thinking that if it needs to be removed that should be easy enough with a small knive to scrape the bead away.
Frenchie
'93 Helix, '02 Reflex, '10 S'wing |
cjuzda Maxi-Scooter Rider
Number of posts: 105 Points: 507 Registration date: 2011-05-16
 | Subject: Any protection for Radiator fins? Sun Jun 12, 2011 8:19 am | |
| I notice that the radiator fins are pretty exposed. Has anyne had a problem with damage to the fins or found a way to put some sort of screen in front of the fins? |
Number of posts: 2160 Location: Winnipeg Canada Points: 3057 Registration date: 2010-05-02
 | Subject: Re: Protecting the radiator Sun Jun 12, 2011 8:24 am | |
 | Subject: Re: Protecting the radiator Sun Jun 12, 2011 2:15 pm | |
| Thanks, I did do a search and found that thread but not much in it in terms of concrete information or anyone who actually put a screen on the rad. Probably should have just revived it instead of starting a new one | bigbird wrote: | As members here delve into the nuances of their Swing, their curiosity drives them to seek info. My suggestion, before posting a question, is to do a search. Almost every imaginable Swing topic has been beaten to death many times over. That's not a bad thing, but searching does eliminate excessive and redundant posting.
Here you go:
http://www.silverwing600.com/t2792-protecting-the-radiator?highlight=radiator+screen |
armelão Scooter Rider
Number of posts: 12 Points: 758 Registration date: 2010-05-11
 | Subject: Re: Protecting the radiator Sun Jun 12, 2011 4:16 pm | |
| Take a look here,you must registrate to see the pictures,it´s realy nice!
http://www.maxiscootersportugal.com/forum/index.php?topic=2782.45 |
Meldrew Silver Wing Expert
Number of posts: 602 Age: 61 Location: Cumbria, England UK Points: 1163 Registration date: 2010-11-16
 | Subject: Re: Protecting the radiator Sun Jun 12, 2011 4:31 pm | |
| Just fit a mud flap or fender extender to your front mudguard to keep road crud and small stones away from the radiator. |
jdeereanton Silver Wing Guru
Number of posts: 1767 Age: 74 Location: Huntsville, AL Points: 3057 Registration date: 2008-12-24
 | Subject: Re: Protecting the radiator Sun Jun 12, 2011 6:02 pm | |
| | exavid wrote: | | ...Might be a bit of a solution looking for a problem. |
Sounds about right. |
