| Strange noise at 5 mph! | |
+5ehaughn CathyN joncallihan JeffR The D 9 posters |
The D Scooter Rider
Number of posts : 41 Age : 70 Location : Plano, TX Points : 4881 Registration date : 2011-01-08
| Subject: Strange noise at 5 mph! Sun Feb 20, 2011 7:37 pm | |
| Hope someone can help a newbie to the Swing. I bought my 2005 around the 1st of January. It had 4600 mi. on it and was a one owner.
The last couple of rides I have noticed a strange noise coming from the rear. Does the variator belt make noise at low speeds. Is this something that I should be concerned about?
Thanks in advance for any help on this.
James |
Number of posts : 2596 Age : 64 Location : Bay Area, Ca Points : 8424 Registration date : 2008-12-19
| Subject: Re: Strange noise at 5 mph! Sun Feb 20, 2011 7:55 pm | |
| James,
The noise is probably from the clutch becoming glazed. You can get rid of this by holding in the front brake and reving the engine up to about 4,000 rpm for 4-5 seconds. The SWing can get this sound if you take off slowly or are caught in stop and go traffic a lot. Try it and see if it works. |
The D Scooter Rider
| Subject: Re: Strange noise at 5 mph! Sun Feb 20, 2011 7:58 pm | |
| Thanks Jeff. I will try this tomorrow and report back. It takes awhile to get used to all of the little ins and outs.
James |
The D Scooter Rider
| Subject: Re: Strange noise at 5 mph! Mon Feb 21, 2011 3:08 pm | |
| Jeff,
Is there any safe way to rev to 4000 rpms and apply the front brake? I did this this morning. It was a little spooky!
James |
| Subject: Re: Strange noise at 5 mph! Mon Feb 21, 2011 3:19 pm | |
| It really isn't bad once you do it. You can even hold the rear brake in too if you want. That is easier to do but just hold one brake in really tight and try it. You will smell a bit of a burning smell but it goes away in a few seconds. Try holding the rear brake instead if you want. |
The D Scooter Rider
| Subject: Re: Strange noise at 5 mph! Mon Feb 21, 2011 3:20 pm | |
| Thanks. I thought I was going to launch this morning. |
joncallihan Silver Wing Guru
Number of posts : 1025 Age : 86 Location : Lafayette, Colorado, USA Points : 6693 Registration date : 2009-02-16
| Subject: Re: Strange noise at 5 mph! Mon Feb 21, 2011 5:52 pm | |
| - The D wrote:
- Jeff,
James Start with the brake engaged. That is static, not moving. :flower: :flower: |
The D Scooter Rider
| Subject: Re: Strange noise at 5 mph! Mon Feb 21, 2011 6:01 pm | |
CathyN Silver Wing Expert
Number of posts : 771 Location : USA Points : 5805 Registration date : 2010-11-15
| Subject: Re: Strange noise at 5 mph! Mon Feb 21, 2011 6:48 pm | |
| I too was wondering about this issue. I have the same noise. I wasn't to sure about holding the front brake in either. Made more sense to hold the rear brake in. Thank's Jeff for clarifying.
Cathy |
ehaughn Maxi-Scooter Rider
Number of posts : 131 Age : 55 Location : Norcross, GA Points : 5253 Registration date : 2010-06-13
| Subject: Re: Strange noise at 5 mph! Mon Feb 21, 2011 10:36 pm | |
| I only have 1,700 miles on mine and it is a 2008.
I also have the same noise. Almost like a belt is slipping.
I notice it more when I come to a complete stop, then go up my steep driveway. |
The D Scooter Rider
| Subject: Re: Strange noise at 5 mph! Mon Feb 21, 2011 10:39 pm | |
| The steep driveway is how I first noticed this noise. |
lcseds Scooter Rider
Number of posts : 54 Points : 4850 Registration date : 2011-02-15
| Subject: Re: Strange noise at 5 mph! Tue Feb 22, 2011 7:08 am | |
| You could also put it up on the center stand for this and stand next to the bike, correct? That might be more comfortable for some. |
alejom Scooter Rider
Number of posts : 64 Location : Atlanta, USA Points : 4859 Registration date : 2011-02-18
| Subject: Re: Strange noise at 5 mph! Tue Feb 22, 2011 10:51 am | |
| It is possible, yes, just keep the rear brake fully engaged to prevent the rear wheel from spinning. The clutch will not be de-glazed if the wheel is allowed to turn.
The D Scooter Rider
| Subject: Re: Strange noise at 5 mph! Tue Feb 22, 2011 1:23 pm | |
| Thanks everyone. Took care of it this morning and no more noises. |
| Subject: Re: Strange noise at 5 mph! Tue Feb 22, 2011 4:31 pm | |
| The D,
And, how did you fix this? |
The D Scooter Rider
| Subject: Re: Strange noise at 5 mph! Tue Feb 22, 2011 4:41 pm | |
| I started the engine and kept the rear brake engaged. I then revved the engine to 4000rpm's and held it for about 5 seconds or so. ...Bad smell.... Then I went for a ride. Haven't heard it since.
James |
Number of posts : 231 Age : 69 Location : Middleburg FL Points : 5111 Registration date : 2010-12-12
| Subject: Re: Strange noise at 5 mph! Tue Feb 22, 2011 7:48 pm | |
| Just curious -- anyone out there with a Malossi clutch; do they do the "tuc-tuc dance" like the stocker? That's tuc-tuc, not tuk-tuk... |
The D Scooter Rider
| Subject: Re: Strange noise at 5 mph! Tue Feb 22, 2011 9:37 pm | |
| This brings up a question from a nube. How long does the clutch last????? |
| Subject: Re: Strange noise at 5 mph! Wed Feb 23, 2011 4:09 pm | |
| Thanks.
I am not comfortable performing this.
You think there is any harm leaving as is? |
jdeereanton Silver Wing Guru
Number of posts : 1995 Age : 76 Location : Huntsville, AL Points : 7643 Registration date : 2008-12-24
| Subject: Re: Strange noise at 5 mph! Wed Feb 23, 2011 4:48 pm | |
| - The D wrote:
- This brings up a question from a nube. How long does the clutch last?????
The clutch lasts quite a while, I'm sure there have been some that have worn out. I have been on the various SilverWing forums since 2006 and I seem to recall reading of 2 or 3 clutch replacements. Due to wear or the overcautious nature of the majority of SilverWing owners? I don't know. - ehaughn wrote:
- Thanks.
You think there is any harm leaving as is? I was skeptical at first about this procedure. I'd even seen photos of a scorched cluch/variator face. Was the scorching due to this procedure? Don't know. I have performed the procedure probably 6 or 7 times in the 5 years we've owned our 2 bikes. No scorching, and the drive belts have not shown any sign of unusual wear at replacement. There is no harm in leaving as is. I'd suggest as an alternative - very spirited starts from a stop. Tough on mileage, but fun and keeps the squeal at bay. Long days of sustained riding in very hot weather can also lead to the dreaded squeal. The aforementioned spirited take off practice tends to keep the squeal down in that instance. |
| Subject: Re: Strange noise at 5 mph! | |
