| | Battery replacement suggestions | |
| Author | Message |
Tagg Silver Wing Rider
Number of posts: 439 Points: 1082 Registration date: 2010-11-14
 | Subject: Re: Battery replacement suggestions Tue Jun 21, 2011 7:45 pm | |
| Here is a very complete conversation on the shorai battery, and a video of the guy hard testing it. I just bought a new battery from batteries + but im going with a shorai.
http://www.triumphrat.net/speed-triple-forum/161257-shorai-life-battery-review.html |
GaryL Super Scooter Rider
Number of posts: 237 Age: 59 Location: Casa Grande, Arizona Points: 943 Registration date: 2010-07-09
 | Subject: Re: Battery replacement suggestions Wed Jun 22, 2011 7:57 am | |
| Impressive!! |
honda_silver Site Admin
Number of posts: 2258 Age: 51 Location: Georgetown, Tx Points: 3605 Registration date: 2008-12-23
 | Subject: Re: Battery replacement suggestions Thu Jun 23, 2011 11:55 pm | |
| I received my Shorai battery and charger on Tuesday. After work, I put the battery on the charger. I did not have to but I wanted to test the charger.
I did not have anytime to install the battery till this morning, I took a day off for a Patriot Guard mission. The Shorai battery case is a little smaller than the original OEM battery, so I added added a thick foam underneath (laying down) and a thin foam on the bottom of the battery. I think the foam reduced some vibration since the majority is covered with foam.
The original OEM battery held a nut securely in place to easily screw on the wires. The Shorai battery has a nut attached to a very squishy foam to fill the space. I had a problem installing the positive screw, I could not thread the screw because of the foam flexing too easily. I inserted a plastic ziptie head behind the foam and cut off the ziptie. I was then able to thread the screw the first time. I dd not have any problem on the negative screw.
The Silverwing started immediately ... it seemed even faster starting than the OEM battery. Subjectively it sounded a little better would be hard to prove ... I would be curious if anyone else notices the same. I also noticed that startup idle RPMs looked to about 100-200 RPMs higher.
I was following another PGR member that was driving 77-80 MPH actual by GPS to meet the group enroute. The RPMs seemed to be a little lower than normal even with my old belt ... I would be curious if anyone else notices the same.
_________________ Bill - Georgetown TX 07 Silver Wing ABS Clearview w/vent, Givi E96/TB19/E52 with Admore Lighting, Alaskan Leather, Wrist Rests, 3M Solas tape, K&N air, Hyperpro spring, Grip Puppies, Airhawk, Utopia backrest, Stebel, Apexcone HIDs, StingerZ LEDs (w/Backoff WigWag), Knight Rider Sequential LED, NGK Iridium, Power Commander III, Manic Salamander, Saeng mirrors, Garmin Zumo 660, Dark-Side Sumitomo Tire  |
eddy Maxi-Scooter Rider
Number of posts: 130 Age: 61 Location: Europe Flanders. Points: 1055 Registration date: 2009-11-27
 | Subject: Re: Battery replacement suggestions Fri Jun 24, 2011 1:07 am | |
| Bill,
Better starting with a better battery i do believe. Because the ignition is more powerfull if the Voltage not is dropping by high load of startmotor.
But once the engine is running, the alternator/regulator takes it all over from the battery.
From then , the battery does nothing but demanding a little current.
So it's hard to believe , the scooter runs better or the rpm's are lower etc..
Eddy |
Number of posts: 2160 Location: Winnipeg Canada Points: 3057 Registration date: 2010-05-02
 | Subject: Re: Battery replacement suggestions Fri Jun 24, 2011 7:27 am | |
| Good report, Bill. I concur with eddy that a battery will only affect the cranking rpm, not the running rpm. Maybe that silicone spray you added to the sliders leaked onto the variator and belt, reducing rolling friction? Just kidding. I'm awaiting my 18 amp-hour Shorai. We have a postal strike in Canada right now and nothing is coming through from the US. When I get my battery I'll post my observations as well. Who knows, maybe you're on to something and eddy and I will have to eat crow. |
 | Subject: Re: Battery replacement suggestions Fri Jun 24, 2011 7:26 pm | |
| | honda_silver wrote: | I received my Shorai battery and charger on Tuesday. After work, I put the battery on the charger. I did not have to but I wanted to test the charger.
Ive read that there significantly lighter, is this true? |
 | Subject: Re: Battery replacement suggestions Fri Jun 24, 2011 7:42 pm | |
| The 14AH Shorai weighs 1.8 lbs. The stock 12 AH battery weighs 8 lbs.
 | Subject: Re: Battery replacement suggestions Fri Jun 24, 2011 9:30 pm | |
| | Tagg wrote: | | Ive read that there significantly lighter, is this true? |
http://www.shoraipower.com/s-72895-FSC600-SilverWing.aspx
The LFX18A1-BS12 was ~6 pounds lighter.
Hammy Touring Scooter Rider
Number of posts: 337 Age: 35 Location: Philadelphia, PA Points: 1097 Registration date: 2010-05-22
 | Subject: Re: Battery replacement suggestions Thu Sep 29, 2011 5:53 am | |
| | thomphoto wrote: | | Got the Shorai battery in today. It came from 303 Cycle thru Amazon. Speedy delivery. Man, that battery is light weight. I thought the box was empty when I first picked it up. I installed it and cranked it up and WOW is all I can say. Now to see what the long term result is. |
I can't find the battery on Amazon - do you have a link for the one you bought? |
Cosmic_Jumper Touring Scooter Rider
Number of posts: 303 Location: damn near Philadelphia, PA Points: 1448 Registration date: 2009-06-12
 | Subject: Re: Battery replacement suggestions Thu Sep 29, 2011 1:07 pm | |
| Try this:
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=shorai+LFX18A1-BS12&_sacat=See-All-Categories |
 | Subject: Re: Battery replacement suggestions Thu Sep 29, 2011 1:12 pm | |
| Well, no matter what, it looks like we're looking at about $170 cheapest price no matter what, unless that discount through ADVrider still applies. |
 | Subject: Re: Battery replacement suggestions Thu Sep 29, 2011 1:27 pm | |
| | Hammy wrote: | | Well, no matter what, it looks like we're looking at about $170 cheapest price no matter what, unless that discount through ADVrider still applies. |
At $170 it's about the same price as Yuasa's YTZ14 S battery which is an upgrade from the OEM YTZ12-S battery.
There's a discount from for ADVRider memebers??? |
 | Subject: Re: Battery replacement suggestions Thu Sep 29, 2011 4:31 pm | |
CathyN Super Scooter Rider
Number of posts: 273 Age: 54 Location: Chicago, IL Points: 881 Registration date: 2010-11-15
 | Subject: Re: Battery replacement suggestions Tue Feb 21, 2012 10:09 pm | |
| I ordered the Shorai LFX18A1-BS12 this morning at 9:30 then a half hour later I decided to order the charger too. From mishacycles.com
I found them on the Shorai site under dealers. I noticed the phone number was located in the Chicago suburbs. I called him last night. Alex is the owner. He answered my questions. The price was $169.95. The charger was $74.95.
He was at my door this evening at 7:15 with products in hand. How's that for service. No complaints here.
Bob and I were at the motorcycle show a couple of weeks ago and Shorai was there. Then I looked up on our Forum here and read more about this battery. So I decided to go with the Shorai. Unbelievable how light this battery is and size. Have yet to put it on.
JeffR_ Site Admin
Number of posts: 340 Age: 52 Location: Fremont, Ca Points: 3682 Registration date: 2010-05-12
 | Subject: Re: Battery replacement suggestions Tue Feb 21, 2012 10:35 pm | |
| Cathy,
I was surprised to find out how much batteries cost and then find out they are so small. I think I paid $150 and just had the shop install it at the same time they changed out my anti freeze. Did yours die on you? Mine lasted about 4 years but I never put it on a charger or battery tender. _________________ Ride Safe,
JeffR_
Givi Airflow, Dr Pulley Sliders (28gr), Power Commander, Air Hawk, K&N Filter
2007 Silver Wing 34,000 miles 2005 Majesty (sold) 12,500 miles 2004 Reflex (sold) 3,500 miles
 | Subject: Re: Battery replacement suggestions Wed Feb 22, 2012 6:25 am | |
| | CathyN wrote: | | I ordered the Shorai LFX18A1-BS12 this morning at 9:30 then a half hour later I decided to order the charger too. |
I think you will like the Shorai.
Old Limey Maxi-Scooter Rider
Number of posts: 171 Age: 67 Location: BOLTON LANCASHIRE ENGLAND Points: 912 Registration date: 2010-06-09
 | Subject: Re: Battery replacement suggestions Wed Feb 22, 2012 12:46 pm | |
| Flipping heck fellas!, i just looked at the info about this battery. I also looked at the price. $189. For a battery!! . I could buy the standard Yuasa battery for £35. That means i could buy about 5-6 batterys for the same price. As my 07 Swing still has the original battery and is performing as it should after 5years i'll stick it I just thought i should add i rarely go more than three days without riding, so i have never charged,or needed to charge, my battery.
txtrkdrvr Scooter Rider
Number of posts: 26 Age: 55 Location: Lake County Florida Points: 135 Registration date: 2012-02-07
 | Subject: Re: Battery replacement suggestions Wed Feb 22, 2012 12:53 pm | |
| Yikes! That is one pricey battery! The weight saving are significant, but will it last that much longer than the original I still have in 09? |
 | Subject: Re: Battery replacement suggestions Wed Feb 22, 2012 1:38 pm | |
| | Old Limey wrote: | | i just looked at the info about this battery. I also looked at the price. $189. |
The equivalent Yuasa battery battery as the OEM was around $160 and way up (last I checked).
I believe Yuasa came out with cheaper grade batteries with cheaper prices.
I will find out how long the Shorai battery will last. I also have the Shorai battery with the Shorai charger._________________ Bill - Georgetown TX 07 Silver Wing ABS Clearview w/vent, Givi E96/TB19/E52 with Admore Lighting, Alaskan Leather, Wrist Rests, 3M Solas tape, K&N air, Hyperpro spring, Grip Puppies, Airhawk, Utopia backrest, Stebel, Apexcone HIDs, StingerZ LEDs (w/Backoff WigWag), Knight Rider Sequential LED, NGK Iridium, Power Commander III, Manic Salamander, Saeng mirrors, Garmin Zumo 660, Dark-Side Sumitomo Tire  |
john grinsel Silver Wing Expert
Number of posts: 528 Points: 1601 Registration date: 2009-08-18
 | Subject: Re: Battery replacement suggestions Wed Feb 22, 2012 2:40 pm | |
| My take----since the bike has no kick start or push start capability---I would go with exact OEM replacement----they work fine. If I keep machine long time, at end of three year time I replace, need it or not. Walking sucks. Battery on my Concours (spare bike) did last 5 years(56,000 miles), at that time I replaced as I knew problems could be coming---it used cheap wet battery from Batteries Plus.
Even in extreme cold my various Hondas have always started and I have used them down to zero F------My Suzuki GS500E was no go in extreme cold-----just take battery out, warm in hot water for half hour or more and you get bike running for the day. Now my new BMW R60/6 ('76) only would go in cold by big downhill.
Fuel Injection has voltage requirements to work----so having decent battery power/condition is important.
I do not use trickle chargers, but daily use of bike keeps battery up. |
 | Subject: Re: Battery replacement suggestions Wed Feb 22, 2012 2:44 pm | |
| The Shorai battery suggested for the Swing here :
http://www.shoraipower.com/s-234986-FSC600-SilverWing.aspx
is an amp monster. It spins the starter motor and engine over much faster than the stock Yuasa. I think it's definitely worth the money. |
 | Subject: Re: Battery replacement suggestions Wed Feb 22, 2012 5:39 pm | |
| Jeff,
I have the original battery. When I started it up after a month it seemed to hesitate a bit. Bob got it started. It didn't take long but made me think maybe I should replace it. I don't want to get stranded. I don't know how it was stored the first 1 1/2 years. He had a carport. And put 3700 miles on it in that time. I have had it 1 1/2 years and put 16,600 miles on it. My first winter I didn't ride for 4 months. This year I rode once the day after Christmas (my birthday) in the last three months. We have had a mild winter. But in the morning it is cold and ther is black ice on the streets. By the time I get home from work it is cooling off and dark.
I can't wait to get back on it.
Cathy |
matthew Touring Scooter Rider
Number of posts: 315 Location: near Madrid/Santa Fe, NM Points: 1615 Registration date: 2008-12-24
 | Subject: Re: Battery replacement suggestions Wed Feb 22, 2012 9:52 pm | |
| http://www.powerstarsla.com/PM912L41.html
I haven't used this battery, but apparently it's been discussed on one or more of the Burgman forums. Two year warranty and a pretty attractive price too. I'm thinking I'm gonna try it when I need a replacement. |
