| Tapered steering head bearings | |
+7Flyingpanman Easyrider SilverFeather oldwingguy yammer Cosmic_Jumper The Bern 11 posters |
The Bern Silver Wing Expert
Number of posts : 897 Location : Telford, UK Points : 4414 Registration date : 2014-11-20
| Subject: Tapered steering head bearings Sun Aug 14, 2016 4:53 am | |
| Had to fit a second set yesterday, the first set I used the Honda WSM method of adjustment, WRONG, it leaves them too loose & causes premature wear This time they are torgued to 30Ft Lbs as recommended by All Balls (found the little bit of paper this time), it feels tight when turning at the yoke, but is nice & easy when the handlebars are fitted, that folks is the main reason for this post. Noteworthy is that removal of the bottom taper race is nigh on impossible by 'normal' methods, after literally 2 hours of struggling & swearing I mig welded a piece of flat bar to the race & punched it out from above, which would not have been necessary had I torqued the bearing in the first place, hey ho we live & learn. Secondary, part numbers (All Balls) : Kit # 22-1037 (fits all years) Lower bearing 99-3523 Lower grease seal 33-1008 Upper bearing 99-3520 Lower grease seal 33-1001 The bearing are 'special' sizes so there is no easily available replacement from bearing factors (in the UK) If anyone fancies trying to get the seals 'direct' there is manufacturer info cast into the rubber : Upper TTO D8168 Lower TTO E5266 |
Number of posts : 4416 Age : 81 Location : damn near Philadelphia, PA Points : 10531 Registration date : 2009-06-12
| Subject: Re: Tapered steering head bearings Sun Aug 14, 2016 8:31 am | |
| Valuable information. Thank you for sharing. Are you suggesting that the OEM bearing be torqued to 30 Ft Lbs to prevent premature failure? Tim |
| Subject: Re: Tapered steering head bearings Sun Aug 14, 2016 3:23 pm | |
| No Tim, (OEM) ball races should be done with spring balance to the WSM spec', the taper rollers need to be at 30 Ft Lbs. My error was to fit the first taper rollers set with a spring balance intead of torqueing with a wrench |
yammer Maxi-Scooter Rider
Number of posts : 100 Age : 63 Location : Malta Points : 4137 Registration date : 2013-05-04
| Subject: Re: Tapered steering head bearings Fri Dec 02, 2016 3:15 am | |
| My Steering head bearings seriously need replacing and came upon this thread as having read elsewhere it seems that the bottom outer race is a pain to get out. Surely there is a lip where even the Special Honda tool needs to grab on to. Can someone who has attempted the task shed some light as to why this is so difficult to tap out from the top as is usually done as I need to be prepared to take the necessary medical precautions before I plan to do this. |
Number of posts : 1936 Location : Hocking Hills U.S.A. Points : 5145 Registration date : 2016-01-29
| Subject: Re: Tapered steering head bearings Fri Dec 02, 2016 6:48 am | |
| Thanks good info, the same applies to G'Wings. Maybe? they are the same bearings I haven't looked at that cross reference. I have a friend that works for a bearing supply company I'll ask him. Info from him has been good, rubber O rings for one all he needs is the old ring or GOOD measurements, some rings / bearing being used for different applications have different numbers for different companies. |
| Subject: Re: Tapered steering head bearings Fri Dec 02, 2016 9:41 am | |
| - yammer wrote:
- My Steering head bearings seriously need replacing and came upon this thread as having read elsewhere it seems that the bottom outer race is a pain to get out. Surely there is a lip where even the Special Honda tool needs to grab on to. Can someone who has attempted the task shed some light as to why this is so difficult to tap out from the top as is usually done as I need to be prepared to take the necessary medical precautions before I plan to do this.
Trust us, that bottom race is virtually impossible to remove. My experience was the same as The Bern's; after several hours of cussing & swearing I got out the Dremel and cut the race to relieve the tension. Not a pretty job, mind you, but it got the job done. For all that aggro I should have put in tapered bearings but, who knew...? Tim |
SilverFeather Scooter Rider
Number of posts : 20 Location : UK Points : 3569 Registration date : 2014-08-10
| Subject: Re: Tapered steering head bearings Fri Dec 02, 2016 10:55 am | |
| replaced mine 2-3 weeks ago- bottom race is a nightmare.
The person before me fit tapered bearing and the bottom outer race had a tiny lip on it (far smaller than OEM bearings). also the previous person who installed them had hammered the outer race seat trying to pry the original race. was not a pretty site.
That being said, I heated the outside frame then gently taped in a flat balded screw driver to lower the bearing enough for me to get a bearing puller in and then slide hammer it out.
But next time definitely, will just cut the bugger out and save the aggro and potential for more damage.
Number of posts : 1012 Age : 73 Location : HI Points : 4133 Registration date : 2015-12-18
| Subject: Re: Tapered steering head bearings Sun Dec 04, 2016 2:50 am | |
Yammer, The problem with the lower race is that it cannot be reached with a driver/bar from the top. You cannot see the race from the top. You need to fabricate a puller from the bottom. I used a washer that was larger than the stem opening and used a nut on the puller shaft. Tightening the nut gradually extracted the lower race where I could position the puller to get a better grasp on the upper ledge of the race. I did install the All Balls tapered head bearings. I did this while recovering from an accident breaking both thumbs, collar bone and five ribs. Wife said that I was not getting a new bike, so I rebuilt it. Had my Swing rebuilt before I could ride again. Took me six months. |
Number of posts : 237 Age : 74 Location : Morecambe, Lancs., UK. Points : 3150 Registration date : 2016-06-03
| Subject: Re: Tapered steering head bearings Sun Dec 04, 2016 5:10 am | |
| Here's a video from the Italian SWing Club showing a curved tool he's obviously made for the job:-
https://www.youtube.com/watch?v=Rx3yHRn-vs4 |
| Subject: Re: Tapered steering head bearings Sun Dec 04, 2016 1:33 pm | |
| [quote=[Edit] I used a washer that was larger than the stem opening and used a nut on the puller shaft. Tightening the nut gradually extracted the lower race where I could position the puller to get a better grasp on the upper ledge of the race. I did install the All Balls tapered head bearings.][/quote]
It took me long enough but I finally realized how you were using that oversize washer. Now what kind of a puller did you use for the initial grasp of the bearing race?
| Subject: Re: Tapered steering head bearings Sun Dec 04, 2016 10:01 pm | |
| Tim, I got to go look at my tools and get back to you. |
zgoldwingman Scooter Rider
Number of posts : 21 Age : 78 Location : Evansville, In. Points : 2850 Registration date : 2016-07-25
| Subject: Re: Tapered steering head bearings Sun Dec 04, 2016 10:30 pm | |
| - Easyrider wrote:
Yammer, The problem with the lower race is that it cannot be reached with a driver/bar from the top. You cannot see the race from the top. You need to fabricate a puller from the bottom. I used a washer that was larger than the stem opening and used a nut on the puller shaft. Tightening the nut gradually extracted the lower race where I could position the puller to get a better grasp on the upper ledge of the race. I did install the All Balls tapered head bearings. I did this while recovering from an accident breaking both thumbs, collar bone and five ribs. Wife said that I was not getting a new bike, so I rebuilt it. Had my Swing rebuilt before I could ride again. Took me six months. I had an '87 BMW K100, which the Service Manual advised to use an arc welder by starting a weld on the race surface from the bottom side, it doesn't take much at all, and use as low of setting as you can, race will fall out pretty quickly. I have a wire feed welder now and I think that would make it a lot easier, but haven't had to replace steering bearings lately that I couldn't drive out the old one from the top side. |
| Subject: Re: Tapered steering head bearings Mon Dec 05, 2016 12:06 am | |
| Subject: Re: Tapered steering head bearings Mon Dec 05, 2016 9:07 am | |
| Thank you for the photos and explanation, Easy. I'm so glad that worked for you.
While I had to slice a slot in the bearing race in order to "relax" the tension and get pried out, I find it amazing that the tips of the puller arm were able to gain purchase on that bearing race.
Having the cut bearing race allows it to be used to drive in the new bearing race without the need of grinding down the o.d. of that old race.
Also Dermeling a tension-relieving slot in an old wheel bearing allows that to be used as a bearing driver for the new wheel bearing. Of course the old bearing balls and inner race fall apart once the o.d. is cut, leaving you with exactly the piece needed for the job.
HORNBLOWER Maxi-Scooter Rider
Number of posts : 171 Age : 68 Location : Birmingham UK Points : 4052 Registration date : 2013-10-08
| Subject: Re: Tapered steering head bearings Mon Dec 05, 2016 5:01 pm | |
| Has anybody tried drilling 3 evenly spaced holes in the steering stem shoulder above where the outer race is and then tapping it out from above? |
| Subject: Re: Tapered steering head bearings Mon Dec 05, 2016 5:13 pm | |
- Thank you for the photos and explanation, Easy. I'm so glad that worked for you.
I read about the dermeling the race but was afraid that I would go to far and damage the stem where the race seats. Thanks for the info about cutting the old race instead of having to grind down the outer surface. |
Number of posts : 221 Age : 70 Location : uk saddleworth Points : 3815 Registration date : 2014-08-24
| Subject: Re: Tapered steering head bearings Fri Dec 30, 2016 7:56 pm | |
| I recently took the bottom outer race out of a swing that i was breaking for spares i did it using a flat bar that i cut and welded in a L shape using the L shape upside down as a leaver i was able to move the race just enough to be able to then knock it out from above quite easy really once i figured out the best way of doing it |
| Subject: Re: Tapered steering head bearings Fri Dec 30, 2016 9:22 pm | |
| Is that a 90° L bend or something less? How long is the short leg?
| Subject: Re: Tapered steering head bearings Sun Jan 01, 2017 1:10 pm | |
| Yes 90° about 6 inch long short bit 1/4 thick bar approx an inch wide i used an old tyre lever (very strong steel) |
DodgetheRog Scooter Rider
Number of posts : 57 Age : 59 Location : Letchworth, United Kingom Points : 2586 Registration date : 2017-05-30
| Subject: Re: Tapered steering head bearings Fri Jul 14, 2017 10:48 am | |
| Here's the tool I made to shift that lower bearing shell: It's a piece of round steel bar (all I could find) bent (and re bent and re bent until I found the right angle) with the tip chamfered to a blade: Once I got the tip lodged on the edge of the shell, a few taps with a mallet and it started to shift. Worked my way around and it just popped out! Have to confess, I thought it was going to be a real hassle but along with making the tool, it all took about half an hour. |
| Subject: Re: Tapered steering head bearings | |
