» Stock seat mods
by crahar Today at 9:24 pm
» Windshield
by Guy Today at 8:40 pm
» Givi Windshield Installation Pictorial
by "Hi Yo" Today at 8:35 pm
» 2004 parting out lots of parts left
by Burboy Today at 8:09 pm
» heavier duty front springs for swing
by The Scootist Today at 7:43 pm
» Another Biker Down รท(
by smorkle Today at 5:17 pm
» US Motorcycle Magazine came in the mail today.
by john grinsel Today at 3:46 pm
» Does anyone have the Side Case Attachments on SW 600
by ian henderson Today at 2:03 pm
» Tailgaters - What to do?
by bigi2000 Today at 12:40 pm
» Introduction
by bigbird Today at 12:34 pm
» Corbin Seat More Leg Room
by bigi2000 Today at 12:17 pm
» interior light with manual switch
by Old Limey Today at 9:03 am
 New squeak in left rear when accelerating
GWPSI
Number of posts: 30
Registration date: 2010-09-17
PostSubject: New squeak in left rear when accelerating   Sun Sep 19, 2010 6:11 am
I was on a ride yesterday afternoon when I heard a squeaking sound coming from the left rear when starting out. It only lasts a few seconds and then stops as I pickup speed. No sound at all when I brake and stop.
Any clues as to what this might be?
Sweendog
Number of posts: 154
Registration date: 2009-07-12
PostSubject: Re: New squeak in left rear when accelerating   Sun Sep 19, 2010 6:58 am
Possibly belt-squeak from the rear pulley. Time for a new belt maybe, or time to clean out the belt housing.
eddy
Number of posts: 130
Registration date: 2009-11-27
PostSubject: Re: New squeak in left rear when accelerating   Sun Sep 19, 2010 7:18 am
I vote for the clutch.
Special if you hear it only when starting from 0 mph.
Or allmost 0 mph.
GWPSI
Number of posts: 30
PostSubject: Re: New squeak in left rear when accelerating   Sun Sep 19, 2010 8:39 am
Thanks guys. I'm on it later today. I'll let you know what I find. Good suggestions.
Number of posts: 1672
Registration date: 2008-12-19
PostSubject: Re: New squeak in left rear when accelerating   Sun Sep 19, 2010 8:55 am
GWPSI,
This happens with the SWing if ridden to conservatively. Mine doesn't do this much at all but when it does this is what I do:
1) Pull in the front brake
2) Rev the engine up to about 4,000 rpm's for about 3-5 seconds
3) Then after you let it go back down to idle just take off and you should not hear the noise.
Sometimes when riding in very slow stop and go traffic or just not accelerating more aggressively from a stop, you can get some glazing of your clutch. You can do the above or take your belt off and de-glaze the clutch shoes. By pulling in the break and revving up to about 4,000 for a few seconds, this will de-glaze your clutch.
It won't hurt anything by doing this. Some won't do this but I have done it a few times and it gets rid of that "squeak" in just a matter of seconds.
_________________
Ride safe,
2007 Silver Wing (30,000 miles)
2005 Majesty 400 (sold 12,500 miles)
2004 Reflex (sold 3,500 miles)
Givi Windshield, top case, vista cruise, power commander, dr pulley sliders, air hawk seat pad, (J. Costa not installed now), kevlar belt
http://www.silverwing600.com
Number of posts: 1739
Registration date: 2009-07-26
PostSubject: Re: New squeak in left rear when accelerating   Sun Sep 19, 2010 1:58 pm
I can testify JeffR's solution works for me.
(Nor do I ride conservatively either!!!!!!!) Laughing
http://www.facebook.com/Waspie41
mitch
Number of posts: 42
Registration date: 2010-09-10
PostSubject: Re: New squeak in left rear when accelerating   Sun Sep 19, 2010 11:39 pm
Hi.
When I was road testing my Silverwing, prior to purchase, I noticed this squeal when starting off from rest and was told it would be fixed under warranty.
The noise, which comes from the lower rear / left hand side of the bike, sounds like a squeaking trolley wheel in need of attention / squealing brake pads but only seems to surface when the bike is fully warmed up.
Sometimes it does not make the noise but mostly it does and I have found it can be overcome, to an extent, by brisk and revvy take offs.
I put the bike in last Tuesday for the dealer to investigate and was told that it needed a new belt, collar and a nylon bush and booked me in.
I duly arrived at the dealership on Friday at 0830 and by 1000 the work was complete and off I went.
I could not believe it when, by the time I arrived home, I heard the sound again and so I phoned the dealer and they said they just did not know what it could be especially after having done the work they did which cost quite a bit and said they would need to contact Honda technical dept to see what was what !!
Watch this space.
GWPSI
Number of posts: 30
PostSubject: I'll try the clutch trick   Mon Sep 20, 2010 4:24 am
Jeff,
You can bet I'll give that a try. I pulled the cover from the belt air filter yesterday and cleaned that. I wanted to check the belt, but you need some exotic allen wrenches to make that happen.
As Mitch noted I have heard this only when the bike was fully warmed up. Not on the initial start.
Thanks to everyone who pitched in with suggestions. I''ll post the result of this latest attempt asap.
Gene
Number of posts: 528
Registration date: 2009-08-18
PostSubject: Re: New squeak in left rear when accelerating   Mon Sep 20, 2010 6:58 am
I think JeffR ----let engine run up against brakes is easiest cure. Noise will come back.
My 09, bought new, SilverWing does it, My Suzuki Burgman 400 did it.I had various drive line troubles with the 4 new Helix I had, noises, 3 of the 4 had rear clutch problems, belt used to also slap against inner case, etc. one broken belt---since cover was easy to get off, shot of Lemon Pledge worked on them ( I know stupid, but worked) all were traded at 36-50,000 miles when warranty ran out. Reflex no noises-its life ended at 22,500 miles when lady on cell phone ran over it.
This noise I treat as nature of the beast in Silverwing---I suspect only low horsepower should be transmitted with belt--maybe 10 HP---my 125 Dealim in Korea, nor Vespa Ciao 50cc in Italy did not have these noises.
John Grinsel
Number of posts: 1724
Registration date: 2009-06-29
PostSubject: Re: New squeak in left rear when accelerating   Mon Sep 20, 2010 12:26 pm
The X9 suffers from the same noise - not a problem and generally happens in hot weather or when doing lots of stop-start riding in heavy traffic.
We called it the 'strangled sealion' noise, cause by the belt slipping a bit.
_________________
Mike - Riding on the right - riding for pleasure!
"All that is necessary for the triumph of evil is that good men do nothing."
Edmund Burke
GWPSI
Number of posts: 30
PostSubject: Burn out seemed to work   Sat Sep 25, 2010 6:23 am
I tried the "lock the front wheel and burn off the belt" technique and the squeak is gone, at least for now. It seems this is not an isolated problem, but fairly common and not serious.
The forum is a great way to sort through these things without an expensive dealer visit.
Gene
PostSubject: Re: New squeak in left rear when accelerating   Sat Sep 25, 2010 7:35 am
Gene,
I'm glad it worked for you. If you are one that takes off slowly it may come back but if you give it more throttle on take off it seems to keep the squeal away for a much longer time. If I take off somewhat aggressively, and I don't mean racing either, then it may not come back. It seems for me that slow take offs and stop and go traffic may bring back that "chirp". I don't a squeal but a very quick "chirp" if I get in slow stop and go traffic or slow starts.
_________________
Ride safe,
eddy
PostSubject: Re: New squeak in left rear when accelerating   Sun Sep 26, 2010 6:19 am
With that whining on departure, the belt is often mentioned.
I think it's the clutch.
And only the clutch.
And it's just annoying.
But do not worry.
» Chevy Rear-end Wanted
» REAR DISK BRAKE SET RM450
» Swing-arm & rear shock linkage maintenance
» what is 1/4 inch square hole in rear fenders for?
» EVO UPGRADED BRAKE KIT REAR - USE WITH 17x8J ET25 TOMBINOS
