» Stock seat mods
by crahar Today at 9:24 pm
» Windshield
by Guy Today at 8:40 pm
» Givi Windshield Installation Pictorial
by "Hi Yo" Today at 8:35 pm
» 2004 parting out lots of parts left
by Burboy Today at 8:09 pm
» heavier duty front springs for swing
by The Scootist Today at 7:43 pm
» Another Biker Down รท(
by smorkle Today at 5:17 pm
» US Motorcycle Magazine came in the mail today.
by john grinsel Today at 3:46 pm
» Does anyone have the Side Case Attachments on SW 600
by ian henderson Today at 2:03 pm
» Tailgaters - What to do?
by bigi2000 Today at 12:40 pm
» Introduction
by bigbird Today at 12:34 pm
» Corbin Seat More Leg Room
by bigi2000 Today at 12:17 pm
» interior light with manual switch
by Old Limey Today at 9:03 am
 Changing the Final Drive Oil Pictorial
Goto page : Previous  1, 2
russcarver
Number of posts: 35
Registration date: 2010-04-14
PostSubject: Re: Changing the Final Drive Oil Pictorial   Sat Oct 02, 2010 11:20 am
The oil change went well. The filler bolt (7/32" hex) does have a washer attached to it as well as another washer behind it (I ride a 2005). Both that washer and the drain bolt washer were metal as stated and in excellent condition so I reused them.
I got a pistol grip oil can with a narrow & long spout that fit perfectly (at Napa auto). It holds 6 oz and I got nearly 3 cans into the hole (the can doesn't fully drain by pumping).
I went with Shell Rotella T5 synthetic blend (same as my engine oil).
Cheers!
--Russ
john123
Number of posts: 116
Registration date: 2010-02-21
PostSubject: Alen wrench   Sun Oct 31, 2010 7:07 pm
The size of the allen wrench would help in your description. Thanks
russcarver
Number of posts: 35
PostSubject: Re: Changing the Final Drive Oil Pictorial   Sun Oct 31, 2010 7:59 pm
As described, it is a 7/32" hex (or allen wrench). I personally used a 7/32" hex drill bit as my allen wrench would not break it free.
--Russ
redeye
Number of posts: 151
Registration date: 2010-10-13
PostSubject: Re: Changing the Final Drive Oil Pictorial   Sat Feb 26, 2011 5:29 pm
JeffR, another thank you for the maintenance pictorials. This afternoon, I decided it was time to change the Silver Wing's final drive oil. Fortunately, I found a 12mm wrench with open-end on one end and six-point box on the other, a quarter inch hex tool, and an oil can with a long nozzle in the garage. Your instructions couldn't have been more accurate. My only regret is not capturing the old final drive oil in a separate container. I am convinced that far more new oil went into the reservoir than old oil came out during the draining process. Having purchased the Swing almost nine years after its manufacture, I am wondering if any of the prior owners replaced the oil. Just as you explained, I kept pumping the oil can after filling it once and refilling it two more times until oil began seeping back out. On my first attempt, the entire process required less than a half hour, including the time I left the garage to allow the old oil to drain completely. My actual hands-on time was probably 10 minutes or so.
Previously, I had performed an engine oil and filter change per your pictorial instructions. Today, the Swing received new final drive oil. Next up is the air filter. Thanks again!
redeye
PostSubject: Re: Changing the Final Drive Oil Pictorial   Mon Feb 28, 2011 5:46 am
My mistake. This was a 6mm hex tool, not quarter inch.
joncallihan
Number of posts: 786
Registration date: 2009-02-16
PostSubject: Re: Changing the Final Drive Oil Pictorial   Mon Feb 28, 2011 7:32 am
--Russ
Russ,
ALL bolt heads, nuts and allen (hex) drive fittings on the Swing are metric.
While a 7/32 inch is CLOSE to 6mm it is not exact.
flower
http://www.joncallihan.com
Page 2 of 2Goto page : Previous  1, 2
» Changing Zetec Camshafts
» Changing Zetec Valve stem seals
» F.A Cup Final - Bin Dippers VS Chelski
» UEFA Europe League 1/2 Final
» Coppa Italia Final Tonight
Honda Silver Wing Scooter Forum :: Honda Silver Wing :: "Pictorials" Maintenance-
