| Author | Message |
Number of posts: 2159 Location: Winnipeg Canada Points: 3055 Registration date: 2010-05-02
 | Subject: Re: Oil change Wed Nov 16, 2011 4:03 pm | |
| | LVScooterBill wrote: | So, the long and short of it--what specific motor oil fits the bill for all those? All the jazzy initials and specs, readily available, 10w40 synthetic, won't hurt my bike or break my bank all in one. Any recommendations?
As long as it's 10W30 or 10W-40 (Honda's recommendation), and has a JASO MA rating, it's your choice. Your options range from several dollars/qt up to $20/qt. I can tell you what I use but I won't tell you what to use. I use Shell Rotella T6 5W-40 synthetic. |
LVScooterBill Maxi-Scooter Rider
Number of posts: 113 Location: Las Vegas, Nevada, USA Points: 473 Registration date: 2011-06-07
 | Subject: Re: Oil change Thu Nov 17, 2011 1:09 am | |
| | bigbird wrote: | I use Shell Rotella T6 5W-40 synthetic. |
Thank you Bigbird for your reply. At least I have a starting point. Okay, now a few questions: First, you & I obviously live in two very different climates so I would expect we might be on different ends of the "Honda recommendation spectrum". That said, I was wondering why you chose a 5w-40 oil instead of a 10w-40. Is it because synthetics have lower weight numbers in comparison with a comparable standard oil? I don't recall seeing a lot of oils with low first numbers like 0w or 5w until synthetics got real popular. So would it be okay to try an oil lower than 10w-40 because it is synthetic? I'm concerned because I'd like to get a full synthetic and with the amount of miles I put on the bike, it'd be a while before I accumulate 8k miles to change it again. All of the talk about the 20w-50 I currently have in the motor being bad in colder starts also concerns me and indeed, I am seeing a little slower cranking on the colder nights we're now getting here. I want to change it out soon before we get a lot colder and I'm driving around with 20w-50. BTW, anyone know the prices of the Honda, Fram and K & N oil filters respectively? |
eddy Maxi-Scooter Rider
Number of posts: 130 Age: 61 Location: Europe Flanders. Points: 1054 Registration date: 2009-11-27
 | Subject: Re: Oil change Thu Nov 17, 2011 1:35 am | |
| Don't blame slower cranking/starting to the oil only.
The main reason is the remarkable lower capacity of the battery when cold/freeze .
People are different. I use cheap (mineral) oil according Honda standards. But good brand.
I think my engine will run 100,000 miles. Then, my age is 81.
jdeereanton Silver Wing Guru
Number of posts: 1767 Age: 74 Location: Huntsville, AL Points: 3056 Registration date: 2008-12-24
 | Subject: Re: Oil change Thu Nov 17, 2011 4:35 am | |
| | LVScooterBill wrote: | Thank you Bigbird for your reply. At least I have a starting point. Okay, now a few questions: First, you & I obviously live in two very different climates so I would expect we might be on different ends of the "Honda recommendation spectrum". That said, I was wondering why you chose a 5w-40 oil instead of a 10w-40. Is it because synthetics have lower weight numbers in comparison with a comparable standard oil? I don't recall seeing a lot of oils with low first numbers like 0w or 5w until synthetics got real popular. So would it be okay to try an oil lower than 10w-40 because it is synthetic? I'm concerned because I'd like to get a full synthetic and with the amount of miles I put on the bike, it'd be a while before I accumulate 8k miles to change it again. All of the talk about the 20w-50 I currently have in the motor being bad in colder starts also concerns me and indeed, I am seeing a little slower cranking on the colder nights we're now getting here. I want to change it out soon before we get a lot colder and I'm driving around with 20w-50. BTW, anyone know the prices of the Honda, Fram and K & N oil filters respectively? |
Bill,
I know I'm going to come off as a wet blanket (or worse), but I can't help myself.
It's just an oil change, not manned flight out of the earths orbit.
Stay within the manufacturers recomendations and buy the oil you like and the filter you like and most importantly the one(s) you can afford. Your mototrcycle won't object to the flavor or show it's disdain for the choice - it can't, it's just a machine. Change oil at the frequency you are comfortable with and with the oil and filter you like and just ride.
My apologies - but it really is just an oil change. |
ulflyer Maxi-Scooter Rider
Number of posts: 155 Location: Lexington NC Points: 398 Registration date: 2011-10-27
 | Subject: Re: Oil change Thu Nov 17, 2011 5:40 am | |
| Bill, I second Bigbirds comments; my climate is about the same as yours and I also use Rotella T6 5-40 synthetic and SuperTech oil filters, both avail at Walmart. Rotella is widely used in motorcycles. You can find motorcycle specific oil at most of the auto stores in 10-40 if you prefer that, in synthetic or dino. As mentioned before, I have a buddy with over 200,000 miles on his '03 Wing, using only dino oil, changed at specified intervals. Same guy....2 belt changes. If you don't ride much, I'd suggest using only dino oil and change now before winterizing, and maybe again in early spring. By putting fresh oil in you get rid of any acidic contaminents in the old stuff while the scoot sits thur the winter. Spring change will rid it of any moisture that might have accumulated from condensation. Thats my take on; others have their own. As Dale said above, its not rocket science, don't worry, be happy. |
 | Subject: Re: Oil change Thu Nov 17, 2011 9:47 am | |
| | jdeereanton wrote: | Bill,
Sheesh man, I'm just trying to learn a subject I know nothing about. As to over-complicating it---er, uh, I think I'm just the latest in a very long line of contributors to this supposed 'needlessly complicated' topic thread and yet seem to be the one catching the flack for it. There has been technical analysis bandied about all over the place for five pages, and I just ask someone to give me the long & short of what it all means and I get the "it's not rocket science man" comment thrown at me? Really.
Ted, thanks for the info. I'm actually able to ride all through the winter here so the bike never sits. By dino I take it you mean old 'dinosaur' style oil. If not, then you can see my level of know how on this subject. |
 | Subject: Re: Oil change Thu Nov 17, 2011 10:04 am | |
| Bill,
I wish you the best, and I believe I prefaced my comments correctly. Sorry about that. |
 | Subject: Re: Oil change Thu Nov 17, 2011 3:59 pm | |
| Bill, by dino I mean regular oil as opposed to "synthetic". Just a bit more info for you: you can use any 10w-40 oil in the SW. It need not be labeled "Motorcycle oil" where you pay a premium as long as the circle on the back of the can does not specify that it is "conservation" (or somesuch). Most other grades of oil, like 10-30, 5-40, 5-20, etc do say that on the back and are intended mainly for autos to improve milage and lack some of the additives that cycles & scooters require. Take a stroll thru Walmart and read the labels.
On the other hand, you can get Valvoline dino motorcycle oil at walmart for under $4 a quart or Valvoline synthetic MC oil for $8. Mobil 1 syn MC oil is just under $10.
I noticed today that Walmart had Penzoil 10-40 in 5 qt jugs for about $15; this is regular 10w-40 dino for cars, and being non-conservation, also suitable for scooters.
Personally, I'd stick with an oil labled JASO/Ma in 10-40 for your climate. Earlier I suggested 5-40 thinking for some reason you were here in the SE, but Vegas is, I believe hotter, so the 10-40 will serve you well all year round, be it dino or syn.
Heres a forum about oils and may be a bit overwhelming at this point but if you scroll down to the section on motorcycles you can read what others say. Many of these ride cycles which use wet clutches....thats where the transmission shares the same oil as the motor...and its highly recommended that motorcycle oil be used as they don't have any undue slippery stuff that will cause the clutch to slip. Most Japanese motorcycles use wet clutches, most BMW's and some other Euro's cycles do not.
In our scooters, we don't have transmissions like cycles so the type oil is not as critical. http://www.bobistheoilguy.com/forums/ubbthreads.php |
 | Subject: Re: Oil change Thu Nov 17, 2011 4:11 pm | |
| For those living in hot climates you may find this info useful if you don't already know. The Swing's oil filter is surrounded by a housing which is heated/cooled by the cooling system. This helps warm the oil from cold as well as cool the oil when it gets hot. For this reason a higher viscosity oil is not needed in the Swing if driving even in high desert temps. As long as the radiator keeps the temp gauge at 3 bars, your oil will always be at a constant temp around 190F. You have no worries about the oil reaching too high temps resulting in thinning and breakdown. That's why 10W-30 is acceptable even in hot climates. Ever wonder why our Swings have a recommended oil change interval of 8k miles and HD's and Victorys less than 5k miles? It's because of the liquid cooling of the engine and the oil cooler. |
 | Subject: Re: Oil change Fri Nov 18, 2011 6:12 am | |
| Bigbird: good info...thanks. Not that it matters but I think Victory has upped thiers to about 8K. Just curious tho, how many of you go the full 8K or anywhere near that? I changed my previous scooters, and will also on the SW, about every 4K. They're just so easy to do, it makes me feel good doing it. In contrast, the Can Am calls for synthetic oil with both oil and filter change every 3K. Its both water and oil cooled, yet the temp guage fluctuates considerable, rising to an "acceptable" level during slow traffic to the point that the radiator fan comes on. It is one highly technical machine and not at all easy to do your own oil changes. Mine has the electric clutch and that model uses a transmission filter as well as one for the motor. Neither are the screw on type; much like the B400. . |
Ishkatan Maxi-Scooter Rider
Number of posts: 128 Age: 57 Location: Monrovia, Md Points: 705 Registration date: 2010-11-16
 | Subject: Re: Oil change Fri Dec 09, 2011 12:26 am | |
| | bigbird wrote: | | ... our Swings have a recommended oil change interval of 8k miles .... |
I read in the owner's manual that the filter change schedule is 4K miles but he oil change interval is 8K miles. If I change the filter the oil comes out....
I think something got dropped in translation. I am going to shoot for 3-4K on everything.
And I just bought the oil and filter at Honda. $35 + $2.50 for a washer for the coolant plug. The old washer will be kept as spare. |
 | Subject: Re: Oil change Fri Dec 09, 2011 5:42 am | |
| http://www.silverwing600.com/t1550-on-line-owners-manual?highlight=owners+manualPlease check page 89 of the booklet pointed to in the link of the first post of the thread. Honda Motors recommends that the oil and filter be changed at the initial service point, 600 miles (1,000 km) and the recommended interval thereafter (for both oil and filter) is every 8,000 miles (12,800 km). Checked both of the owner's manuals we have in our garage and my service manual for a cross reference - same result. Yes, I know the link is to a 2005 owner's manual. No fault there, the 2009 owner's manual that bigbird most likely used to come up with the original 8,000 figure serves as an ample cross check. |
 | Subject: Re: Oil change Fri Dec 09, 2011 6:12 am | |
| | Ishkatan wrote: | And I just bought the oil and filter at Honda. $35 + $2.50 for a washer for the coolant plug. . |
Or you could buy the oil and filter at Walmart (or substitute any auto parts store) for under $15. |
tinman Maxi-Scooter Rider
Number of posts: 156 Age: 63 Location: Matheson, Ontario, Canada Points: 355 Registration date: 2011-11-29
 | Subject: Re: Oil change Tue Dec 13, 2011 10:39 am | |
| I just changed my oil and filter to day. I used Castrol full Synthetic oil 5 w 40. I for one thought all synthetics where all the same and superior to regular oil. I installed a WIK 51356 filter .After oil change I notice ABS light was on,and stayed on. I figured , being on the center stand ,was the cause for ABS light to stay on. A Respond would be appreciated . |
 | Subject: Re: Oil change Tue Dec 13, 2011 11:23 am | |
| Oddly enough my previous post contains a link that will take you to an owners manual. Check page 19.
"ABS indicator light Lights when there is any abnormality in the anti-lock brake system (ABS). Normally, this indicator comes on when the ignition switch is turned ON, and goes off after you ride the scooter at a speed above 6 mph (10 km/h). If the indicator comes on while riding, stop the scooter in a safe place and turn off the engine. Refer to , page . For information about ABS, see page 70 Lamp Check." |
 | Subject: Re: Oil change Tue Dec 13, 2011 12:12 pm | |
| | tinman wrote: | | .After oil change I notice ABS light was on,and stayed on. I figured , being on the center stand ,was the cause for ABS light to stay on. A Respond would be appreciated . |
That is correct and normal. Both wheels need to rotate at the same time for the ABS self-test light to go out. |
Number of posts: 1739 Age: 60 Location: Portland, UK Points: 2904 Registration date: 2009-07-26
 | Subject: Re: Oil change Tue Dec 13, 2011 12:53 pm | |
| Tinman do you have a 'User Manual' the one that comes with the bike. It is available online in .pdf format. It will answer a lot of your 'light' questions regards to what lights are on/off in the various power modes.
I'll try and locate the link. |
 | Subject: Re: Oil change Tue Dec 13, 2011 1:12 pm | |
| Link for Owners manual.
http://www.hondampe.com.au/docs/owning_a_honda/owners_manuals/motorcycles/FJS600DA-2007.pdf |
 | Subject: Re: Oil change Tue Dec 13, 2011 2:23 pm | |
| yes I have a owners manual It was in my sw and I retrieved it to day when I pulled my sw to do my oil change .I will read it again to understand my sw better. I will have to read again tonight. |
 | Subject: Re: Oil change Tue Dec 13, 2011 2:30 pm | |
| | tinman wrote: | yes I have a owners manual It was in my sw and I retrieved it to day when I pulled my sw to do my oil change .I will read it again to understand my sw better. I will have to read again tonight. |
I have to admit it is probably the only manual of all my 'toys' I refer to. Simple jobs like resetting the clock when we, (UK,) move between time zones. Even tyre pressure elude me at times. (Age I suppose.) |
 | Subject: Re: Oil change Tue Dec 13, 2011 5:40 pm | |
| I know. If its not one thing " Its Two " |
