| | Givi AirFlow Adjustable Windshield Review | |
| Author | Message |
Number of posts: 2159 Location: Winnipeg Canada Points: 3055 Registration date: 2010-05-02
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Tue Jul 20, 2010 9:03 pm | |
| | ronjr009 wrote: | | I cut the brackets off of the front fairing piece that covers the windshield so that onlythe screws are holding it in. |
I had thought about that. Don't you find that the windshield garnish now buzzes and vibrates at higher speeds? |
buddy19520 Super Scooter Rider
Number of posts: 286 Location: Cornelius NC Points: 1128 Registration date: 2010-02-27
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Wed Jul 21, 2010 3:12 pm | |
| JeffR, thanks for the follow up. I had just kind of wondered if the stock shield with LL was as quiet as the new GIVI. Sounds like you feel it is close, but the new GIVI is quieter.
I am doing the same thing as Ron is doing - GIVI in the cool/cold weather and the stocker in the warm weather, both with the LL. I find the LL makes a big difference on both screens. I'll probably continue with this system until one of the screens breaks, only for cost reasons (read: too cheap to pay for another screen). |
ronjr009 Maxi-Scooter Rider
Number of posts: 179 Location: Greeneville, TN Points: 1473 Registration date: 2008-12-28
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Wed Jul 21, 2010 6:33 pm | |
| Hi Bigbird,
Honestly, I've not noticed any kind of buzzing or noise associated with cutting off the tabs. I just got so sick and tired of trying to fuss with getting it off that I simply decided it was time for the tabs to go. The screws do a great job of holding it in place. I think you should be fine if you cut the tabs off. You will be a whole lot happier and less frustrated come time to change the windshields. Even if by chance you do happen to notice any noise or vibration, you could always use something to "dampen" it such as adhesive backed foam or something similar. But I think you'll be fine though as I've never had any noise problems. |
Number of posts: 1672 Age: 52 Location: Fremont, Ca Points: 2942 Registration date: 2008-12-19
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Wed Jul 21, 2010 6:47 pm | |
| I never thought about cutting off the tabs but I can usually get mine off in just a few seconds though. I lost my screws somewhere and only the tabs are holding it in and it doesn't rattle either. _________________ Ride safe, JeffR 2007 Silver Wing (30,000 miles) 2005 Majesty 400 (sold 12,500 miles) 2004 Reflex (sold 3,500 miles) Givi Windshield, top case, vista cruise, power commander, dr pulley sliders, air hawk seat pad, (J. Costa not installed now), kevlar belt  |
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Thu Jul 22, 2010 10:43 am | |
| I can get the garnish off and swap windshields in 10 minutes with tabs and screws. The key to the tabs is this: 1) Remove the 4 screws holding the garnish in place. 2) Pull down gently on the TOP of the garnish right under the windshield to loosen the black wind opening vent and top screw mounts. 2)Take a thin piece of plastic like a credit card and insert it into the top of the garnish beside the turn signal. Slide the card down inside the garnish until it reaches the outside bottom of the garnish. The card will pull the garnish out enough to relieve the pressure on the tab. 3) With the plastic still inserted at the bottom of the garnish, use your fist to lightly punch the top of the garnish just under the windshield. The sharp downwards jolt will release the tab. Do the same thing on the opposite side of the garnish to release the opposite tab. This is guaranteed to not break the tabs off.
For reinstallation, push the garnish back on so that the wind vent lines up inside the front above the headlight. Press down at the bottom of the garnish to get the tabs re-engaged behind the plastic. Then line up the screw boxes at the top of the garnish. If the lower garnish is not fully seated, take your fist and lightly pound on the bottom of the garnish to seat both tabs. Reinstall the 4 screws. The order shouldn't matter. |
Tamjay Scooter Rider
Number of posts: 54 Age: 70 Location: Lincolnshire UK Points: 777 Registration date: 2010-06-10
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Fri Jul 23, 2010 1:33 am | |
| I'm delighted to say that my windshield arrived today from the US - it's taken about 10 days but I've got it at last.
Looking at the instructions (which are barely readable!!), it looks as if I've got to drill some holes before fitting. Did you guys drill anything? I don't remember reading anything about that in the 'pictorial instructions' or your posts.
If that's going to be the case, I may take it to my dealer to get it fitted - I don't trust myself to do it !!
Laurie |
tonylumps Maxi-Scooter Rider
Number of posts: 145 Age: 68 Location: Newtown Square Pa Points: 940 Registration date: 2010-04-26
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Fri Jul 23, 2010 4:04 am | |
| Laurie you are right the instructions have a lot to be desired.The reason for drilling the holes is for the 2 mounting brackets A good number of Swing owners do not mount the brackets, So no drilling and it has been fine. Now what I found out from all the good info. here Is that Givi and Honda had a love affair at one time The Swing was made to except a lot of givi after market Acc.So when you mount the brackets with existing bolts There is a place for 2 more bolts on each side If you drill about 3mm deep at these locations just thru the plastic there are 2 capture nuts under the plastic I used a drill bit slightly larger then the bolts that came with your shield. Reason you get confused is the instructions don't tell you why you are drilling and that the nuts are already there. I mounted the 2 brackets I think it makes it a lot stiffer If you are still a little leary about doing it you can take it to a Dealer But they might know less than you Tony |
trooth2u Scooter Rider
Number of posts: 15 Age: 65 Location: Warrenton, VA Points: 699 Registration date: 2010-07-11
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Fri Jul 23, 2010 5:32 am | |
| I just mounted it like you would mount a stock shield...didn't drill any holes and it's fine and very stable...less flexing than any shield I've used before. Jules...Warrenton, VA |
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Fri Jul 23, 2010 7:06 am | |
| I also haven't used the metal brackets on either the GIVI or Airflow. I haven't had any problems with flexing or stress cracking around the 6 standard holes. But then again I don't drive above 120 km/h, nor into hurricane force winds. |
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Fri Jul 23, 2010 8:16 am | |
| Laurie, I tried to use the metal strip but just put it aside since I didn't use it on the standard Givi shield either. And like Tony said, the dealers sometimes don't know anymore than the average SWing owner so you may want to try to do this yourself. There is a "Pictorial" that should help you out in the "Pictorial" section. It should only take about 30 mins the first time you do this. _________________ Ride safe, JeffR 2007 Silver Wing (30,000 miles) 2005 Majesty 400 (sold 12,500 miles) 2004 Reflex (sold 3,500 miles) Givi Windshield, top case, vista cruise, power commander, dr pulley sliders, air hawk seat pad, (J. Costa not installed now), kevlar belt  |
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Sun Jul 25, 2010 12:07 am | |
| Well, I managed to fit the screen yesterday. It took me about 45 minutes without losing any screws, washers, grommets or breaking any tabs!! Took it out for a test run and, my goodness, what a difference it's made. It's quieter (I can hear myself think!), not much buffeting at all and even in the slip-stream of trucks and cars it felt much more stable. What I love about it is that it can be adjusted by millimetres. I was afraid that it only had 3 settings (bottom, middle, top), so I have it set exactly where I want it. Thanks again for all your tips and help guys. Couldn't have done it without you!! Laurie |
trouble1100 Maxi-Scooter Rider
Number of posts: 176 Age: 55 Location: Plum Pa Points: 1011 Registration date: 2010-04-30
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Sun Jul 25, 2010 7:16 am | |
| For those of you that did not drill the plastic I'm here to tell you it's not a big deal.
When you mount the stainless plate without the shield in place and drill thru the plastic all you are doing is exposing a pre drilled / threaded boss in the steel frame that holds the entire front fairing to the scoot.
Light pressure on the drill and the plate for a guide will put you on the mark to use that third mounting point.
BTW .... Stress cracks in the future or miss drilled holes now will set you back the price of a new front nose piece .... $320. to $370. depending on the year and or color. |
edbancro Maxi-Scooter Rider
Number of posts: 158 Location: Western Pennsylvania Points: 1114 Registration date: 2009-10-30
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Sun Jul 25, 2010 2:22 pm | |
| | trouble1100 wrote: | | For those of you that did not drill the plastic I'm here to tell you it's not a big deal. |
I second that.
Also, it's not necessary, but if you want to have a better view, I seem to remember that that black plastic piece (the one that sort of forms the dash/top of inst. cluster) comes out with just a couple screws and clips, and then you can see the nut and exactly what you're drilling into. |
billc. Maxi-Scooter Rider
Number of posts: 124 Age: 63 Location: Atlanta, Ga. Points: 981 Registration date: 2010-02-19
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Sun Jul 25, 2010 6:37 pm | |
| Where is a good place to buy this windshield? thanks billc. and what is a good price? |
jdeereanton Silver Wing Guru
Number of posts: 1767 Age: 74 Location: Huntsville, AL Points: 3056 Registration date: 2008-12-24
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Mon Jul 26, 2010 3:40 am | |
| Twisted Throttle has them - it seems the standard price is $215 and change. |
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Mon Jul 26, 2010 5:51 am | |
| I bought mine at Helmet Head for $215.09 free shipping, arrived quickly. See http://tinyurl.com/2aflmtf Best, Jules
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Mon Jul 26, 2010 10:39 am | |
| I just finished removing my Airflow, installing the GIVI mounting plates, and reinstalling the Airflow. It took all of 20 minutes. After reading several posts by members who had used the GIVI plates, I decided to revisit this issue.
When I first bought the GIVI, I read (that's a joke unto itself) the pathetic instructions and assumed that I had to drill the windshield itself to install the plates. When I realized I only had to drill through the tupperware in 2 places to install both plates I decided it was worth my time.
Why? As others have said, basically it's the tupperware that supports the windshield if you don't use the plates. It's not the windshield that will develop the stress cracks over time, it's the Swing bodywork. Not a good plan, as again others said to replace any panels you'd be looking at $350+.
With the plates installed, now the 3 screws on each side of the windshield base are supported by the plate, which in turn is now firmly attached by 2 screws into the metal frame structure under the tupperware. I often wondered why GIVI included the plates which most people ignored. Their engineers are much smarter than I am. Why include mounting hardware that costs extra to engineer and manufacture if it's not 100% necessary?
That being said, I'm certainly not the be all and end all authority on this kind of stuff, but I really think those Swing owners who installed any GIVI windshield without the plates rethink their strategy.
One last tip for anyone working on any scooter. When dealing with fasteners, nuts, bolts, etc don't be in a hurry and hold more than one bolt, screw, washer, etc in your hand at one time. For example, when reattaching the windshield don't put all 6 screws in one hand and start screwing one at a time. The chances of dropping anything in your other hand while screwing goes up significantly. Ever drop a fastener down into the abyss inside the tupperware? I did the first time I did any work on my Swing. Fortunately I had a supply of metric screws and it wasn't a biggy. DO NOT be in a hurry and only hold one fastener at a time. That's my tip of the day. Hey, there's a new thread jumping out at me. "Tip of the Day" about your Swing. |
Number of posts: 1724 Age: 62 Location: Western Europe Points: 2866 Registration date: 2009-06-29
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Mon Jul 26, 2010 11:04 am | |
| Bigbird, how obvious is it where to drill the two holes? _________________ Mike - Riding on the right - riding for pleasure!
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Mon Jul 26, 2010 11:21 am | |
| | MikeO wrote: | | Bigbird, how obvious is it where to drill the two holes? |
Where the tab bends inwards, just under the bottom of the windshield. You loosely install the plates and you gently drill the far left hole. |
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Mon Jul 26, 2010 11:48 am | |
| Ta muchly! _________________ Mike - Riding on the right - riding for pleasure!
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Mon Jul 26, 2010 12:22 pm | |
| On mine, I think I also remember some sort of circular markings in the tupperware which seemed to indicate where the holes need to be drilled. I don't know if that's why they were there or if it's something else from the manufacturing process. Has anyone else noticed this? |
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Mon Jul 26, 2010 12:45 pm | |
| To respond to Bigbird about being in a hurry.And also DO NOT PUT ANY IN YOUR MOUTH unless it is small enough to pass or you have extras. Don't even ask. Tony |
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Mon Jul 26, 2010 2:33 pm | |
| | tonylumps wrote: | | To respond to Bigbird about being in a hurry.And also DO NOT PUT ANY IN YOUR MOUTH unless it is small enough to pass or you have extras. Don't even ask. Tony |
I want to ask |
crahar Super Scooter Rider
Number of posts: 241 Age: 64 Location: Beaumont, Texas Points: 1249 Registration date: 2009-08-31
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Mon Jul 26, 2010 2:45 pm | |
| The National Enquirer said inquiring minds want to know. They would like a full write up plus pictures, said it should make the front page next to Elvis sighting in Afghanistan. Craig |
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Mon Jul 26, 2010 2:55 pm | |
| Well lets just say I am glad I had a spare Tony |
honda_silver Site Admin
Number of posts: 2257 Age: 51 Location: Georgetown, Tx Points: 3603 Registration date: 2008-12-23
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Mon Jul 26, 2010 10:20 pm | |
| | billc. wrote: | | Where is a good place to buy this windshield? thanks billc. and what is a good price? |
$215.09 with free shipping http://www.helmetheadcycle.com/product/12546/givi-af214-honda-silver-wing-400-600-2801-0929-airflow-windshield_________________ Bill - Georgetown TX 07 Silver Wing ABS Clearview w/vent, Givi E96/TB19/E52 with Admore Lighting, Alaskan Leather, Wrist Rests, 3M Solas tape, K&N air, Hyperpro spring, Grip Puppies, Airhawk, Utopia backrest, Stebel, Apexcone HIDs, StingerZ LEDs (w/Backoff WigWag), Knight Rider Sequential LED, NGK Iridium, Power Commander III, Manic Salamander, Saeng mirrors, Garmin Zumo 660, Dark-Side Sumitomo Tire  |
thomphoto Maxi-Scooter Rider
Number of posts: 188 Age: 75 Location: Owensboro, Kentucky Points: 1312 Registration date: 2009-06-11
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Wed Jul 28, 2010 12:44 pm | |
| Hi All, I just returned from a 1200 mile ride, including Deal's Gap, and the Tail of the Dragon, with 4 Harleys, 1 Goldwing, 1 Reflex, and my Silverwing. This was the first long trip with my new Givi Air Flo windshield. I'm glad to report that this windshield is the best one that I have had, and that includes the regular Givi, and 3 sizes of Clearview. On the interstate, I kept it at about the halfway mark which allowed me to just see over it. There was no buffeting, but it let a nice breeze come around, just enough to be comfortable in the 90+ temps. In the twisties I put it at the lowest setting which allowed a really good view of the road ahead. I tried the lowest setting on the interstate, and I did get some buffeting on my helmet, but you would expect that. I was able to adjust it up or down with 1 hand while riding (slowly). The only issues I had was a lot of flutter at high speeds, but that was not a problem since I was looking over it, and there is some distortion if you try to look thru it. Overall, I highly recommend it.
Wendell |
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Wed Jul 28, 2010 12:59 pm | |
| | thomphoto wrote: | | The only issues I had was a lot of flutter at high speeds, but that was not a problem since I was looking over it |
Was the fluttering front-back movement at the top of the windshield??
Do you have the optional bracket installed ... I wonder if that was intended for high speed movement._________________ Bill - Georgetown TX 07 Silver Wing ABS Clearview w/vent, Givi E96/TB19/E52 with Admore Lighting, Alaskan Leather, Wrist Rests, 3M Solas tape, K&N air, Hyperpro spring, Grip Puppies, Airhawk, Utopia backrest, Stebel, Apexcone HIDs, StingerZ LEDs (w/Backoff WigWag), Knight Rider Sequential LED, NGK Iridium, Power Commander III, Manic Salamander, Saeng mirrors, Garmin Zumo 660, Dark-Side Sumitomo Tire  |
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Wed Jul 28, 2010 1:05 pm | |
| Yes, the flutter was front back movement on the lower section. And I did not install the brackets, but I will be doing that soon to see if that makes a difference. By the way, my gas mileage for the 1200 miles was 54 MPG and that included about 300 miles of interstate at 70 indicated. |
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Wed Jul 28, 2010 1:58 pm | |
| | thomphoto wrote: | | Yes, the flutter was front back movement on the lower section. And I did not install the brackets, but I will be doing that soon to see if that makes a difference. |
Let us know.
| thomphoto wrote: | | By the way, my gas mileage for the 1200 miles was 54 MPG and that included about 300 miles of interstate at 70 indicated. |
Would that be lower, normal or higher from prior MPG comparisons??_________________ Bill - Georgetown TX 07 Silver Wing ABS Clearview w/vent, Givi E96/TB19/E52 with Admore Lighting, Alaskan Leather, Wrist Rests, 3M Solas tape, K&N air, Hyperpro spring, Grip Puppies, Airhawk, Utopia backrest, Stebel, Apexcone HIDs, StingerZ LEDs (w/Backoff WigWag), Knight Rider Sequential LED, NGK Iridium, Power Commander III, Manic Salamander, Saeng mirrors, Garmin Zumo 660, Dark-Side Sumitomo Tire  |
