| | Givi AirFlow Adjustable Windshield Review | |
| Author | Message |
Number of posts: 2158 Location: Winnipeg Canada Points: 3054 Registration date: 2010-05-02
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Wed Sep 08, 2010 6:05 am | |
| | MikeO wrote: | Just a quickie confirmation: I'm assuming that to drill the two holes one does NOT have to remove any tupperware other than the front panel. Is that correct? |
Correct. The windshield garnish only needs to come off. |
Number of posts: 1724 Age: 62 Location: Western Europe Points: 2866 Registration date: 2009-06-29
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Wed Sep 08, 2010 6:26 am | |
| Thanks bigbird - I'm in 'Oh God, will I be able to manage it?' mode! I usually do. _________________ Mike - Riding on the right - riding for pleasure!
clarinet Scooter Rider
Number of posts: 1 Age: 73 Location: Great River, NY Points: 647 Registration date: 2010-08-16
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Wed Sep 08, 2010 6:52 am | |
| Just an a FYI, when I installed mine over the weekend I did remove the top cover over the instrument cluster. It allowed me to see where I was drilling so that I did not drill into the boss and screw that up. Doesn't have to be done, however, just was a bit easier for me. (These things happen when you get old!) |
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Wed Sep 08, 2010 6:56 am | |
| | MikeO wrote: | | I'm in 'Oh God, will I be able to manage it?' mode! |
This is the easiest mod you'll do. You're only drilling through the tupperware. About 3 revolutions of the drill bit and you're through. As Clarinet said you can remove the top cover from the instrument panel to see the angle that you should drill. You need to line up the template holes with the bosses attached to the Swing frame. |
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Wed Sep 08, 2010 7:08 am | |
| Thank you!  _________________ Mike - Riding on the right - riding for pleasure!
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Thu Sep 09, 2010 3:41 am | |
| Panic mode! Two holes each side to drill? _________________ Mike - Riding on the right - riding for pleasure!
edbancro Maxi-Scooter Rider
Number of posts: 158 Location: Western Pennsylvania Points: 1114 Registration date: 2009-10-30
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Thu Sep 09, 2010 5:13 am | |
| Thanks! I was confused by having to remove one of the big shiney bolts from either side and replace them with the two supplied. Job's jobbed without any real hassle, not least because of the wealth of information and support here - the supplied instructions are very clear.......when they've been explained here! I dropped only one washer - one of the plastic ones - so made one from a piece of plastic I had in my workshop. My hand guards do push slightly on the screen at full-lock; I shall go for a ride later and assess the situation. Thanks again to everyone.  _________________ Mike - Riding on the right - riding for pleasure!
GYROB Scooter Rider
Number of posts: 12 Points: 1086 Registration date: 2009-06-14
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Thu Sep 09, 2010 5:15 am | |
| Im STUCK already. i have take the 2 screws out of the front air intake and the 2 at the back the plastic is lose but how do you get it off . it feels like its clipped in near the indicater lights . anyone ? Rob. |
GYROB Scooter Rider
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Thu Sep 09, 2010 5:23 am | |
| GOT it just found BigBirds way of doing it  Rob |
GYROB Scooter Rider
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Thu Sep 09, 2010 7:08 am | |
| All back togather it took about an hour. i did break one of those hooks at the front afterall but easy to repair ,that bit was the hard bit the hooks were so darnd tight .
we have rain now so a test will have to waite ..
i do like the look of it as it give the bike more prominanc . Rob |
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Thu Sep 09, 2010 7:16 am | |
GYROB Scooter Rider
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Thu Sep 09, 2010 11:24 am | |
| Just back from a little ride and the screen is a great improvment over the standared honda one . the wind noise with my helmet is 70% quieter, befor i could not stand the noise i got with my viser down it was a constant roar NOW i can easyly ride with my viser down . Thanks for the views on it here as it helped me decide to try one . very happy  Rob. |
john grinsel Silver Wing Expert
Number of posts: 525 Points: 1595 Registration date: 2009-08-18
 | Subject: adj Givi shield FOG Fri Sep 10, 2010 4:42 pm | |
| As I have stated before--- the new shield works ok up to 65 or maybe 70mph. Works better than others I have tried/ wasted money on.
Today----Monroeville, AL to Chattanooga---early AM back roads----was able to ride thru several ground FOG conditions.-----Of course both sides of shield end up foggy....but no big drops roll off in my face/eyes so passes test. Those looking thru are putting themselves in good position to getting killed-----look over worked great.
Next have trip to DC and one to MO and letter upper MI, bound to run into rain....snow in UP?
John Grinsel |
Windrider Maxi-Scooter Rider
Number of posts: 133 Age: 73 Points: 826 Registration date: 2010-07-05
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Tue Sep 21, 2010 5:43 am | |
ehaughn Maxi-Scooter Rider
Number of posts: 131 Age: 43 Location: Norcross, GA Points: 926 Registration date: 2010-06-13
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Tue Sep 21, 2010 6:26 am | |
| Givi recommends you use the metal brackets, which provide additional stability. |
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Tue Sep 21, 2010 6:58 am | |
| My review of the Givi screen is this:
Noise and buffeting are reduced beyond measure, even in the gale-force wind I experienced on the motorways.
There is some wind-noise at speed but the pounding on the ear-drums has vanished and it's a motorcycle so is never going to be completely draft- and noise-free. My ipod was at just over half the volume than with the original screen and that was at speeds over 70MPH.
I think it's altered the handling a bit; I'm guessing that the venturi-effect is pressing the front of the bike harder on the road, causing the rider (me) to have to be a bit more positive in recovering from HGV bow-waves - the screen is less 'slippery' from side to side so appears to be caught by cross-winds. It may be my imagination and is certainly not a problem, my having adjusted to it. It hasn't spoilt the ride.
I set the height in the garage and didn't try moving it up or down. I might lower it a fraction to see what's what but on the few occasions one has to look at the road directly in front and therefore look through the screen, there is no distortion at all.
Sorry this is so short - there's really not much to say. It is not perfect but very nearly and I'm very pleased I made the decision.
It's also very easy to attach - I was panicking about drilling the two extra holes but it's a piece of cake.
Not important but it hasn't spoilt the look of the bike - Silverwing and Burger rider-friends with whom I was in Brittany commented on that very point.
If you can scrape together the cash, buy one - that's my recommendation. _________________ Mike - Riding on the right - riding for pleasure!
Number of posts: 1738 Age: 60 Location: Portland, UK Points: 2903 Registration date: 2009-07-26
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Tue Sep 21, 2010 7:06 am | |
| MikeO, cut and paste - great invention.
Been following the exploits of the Givi screen all over the net!!!!!
Nice review, will def. get one in the next couple of months. |
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Tue Sep 21, 2010 7:57 am | |
| It took me enough effort to write one - I'm not doing a new one for each set of fans on the net, Doug! Have you found the one with a UK supplier's link? _________________ Mike - Riding on the right - riding for pleasure!
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Tue Sep 21, 2010 10:25 am | |
| | Windrider wrote: | | I just put a AirFlow on my SWing, I did not do any drilling, but used the 6 screws that hold the old screen on. Did I do something wrong? . |
Did you do anything wrong? You didn't do a complete isntall as suggested by GIVI. The stock Honda screen anchors 2 of its 6 screws into the frame. The other 4 are only attached to the tupperware front cover. The GIVI, being bigger with more surface area, may require a more secure mounting. GIVI suggest attaching their brackets to the frame at the mounting points shown in their very poor instructions. Do a search here on GIVI airflow and you will find lots of mounting information. The general consensus is that any GIVI should be mounted using their metal brackets. The tupperware may stress and crack over time if you don't use the 4 frame mounting points for their windscreens. I orginally didn't use their brackets, but after having the front cover off and seeing the weakness of the stock mount I installed the GIVI brackets. It's really not a big deal. |
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Wed Sep 22, 2010 5:37 am | |
| Thanks BigBird I will go back and install the braces. I don't want it to break. |
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Wed Sep 22, 2010 9:53 am | |
| | Windrider wrote: | Thanks BigBird I will go back and install the braces. I don't want it to break. |
I concur. Initially I didn't use the braces either, thinking I was smarter than GIVI. Not. After reading here about the windshield attachment points to the tupperware rather than the frame, I understood why GIVI added the braces. They would never provide extra parts for no reason. Their engineering dep't specified braces, so braces it is. |
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Wed Sep 22, 2010 1:12 pm | |
| | MikeO wrote: | | Have you found the one with a UK supplier's link? |
Yes thanks Mike, saved for future reference. |
 | Subject: final from me on this shield Sat Sep 25, 2010 12:28 pm | |
| Finally after near 4,000 miles with this windshield, got to ride in some rain today.
Seems to work ok in lower position---no large drops directed to my face. Lower position for me about one inch from lowest possible.
I can see in west, you could raise it some for all day rain ride----I had to contend with idiots today going to TN football game in their pickups and SUV's. Not good or considerate drivers---guess they don't know it can be slippery when wet. Was not good time to experiment, better to concentrate on staying alive.
So Givi adj shield works as good or better than I have tried----does make up for some of the design flaw in basic scooter, your nose being too far from tip of screen. At slower speeds beautiful-----at speeds above 65-70mph can still be a little bothersome----but much better than stock or other after market windshields
John Grinsel |
jimjotel Scooter Rider
Number of posts: 77 Age: 62 Location: atlanta ga. Points: 991 Registration date: 2009-12-01
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Sat Sep 25, 2010 3:55 pm | |
| what windsheild did you replace it with John? |
Number of posts: 2397 Points: 4094 Registration date: 2008-12-28
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Sat Sep 25, 2010 4:38 pm | |
| Hey John, I'm happy to hear you like your new GIVI AirFlow windshield. Makes me, really want one. Maybe some day soon, I hope. Thanks for taken the time to write a little something. |
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Sat Sep 25, 2010 8:32 pm | |
| The Givi replaced Clearview, cut to see over with GoldWing vent, prior to that stock with laminar lip and ears......that combo didn't provide much buffeting relief. Clearview a little better, but not good enough for real riding, assuming you have standard to compare to. I do.
Givi will stay with bike until I get rid of....it is 09.....so always thinking of next one.
John Grinsel |
 | Subject: Re: Givi AirFlow Adjustable Windshield Review Sun Sep 26, 2010 1:31 pm | |
| No apology needed, but thanks.
Doug's point was that he'd seen my review on several forums that we both frequent. I'm happy to answer any specific questions about the screen although other members have given far more details than I have - I just think it's very, very good. _________________ Mike - Riding on the right - riding for pleasure!
