| | | Author | Message |
daffy Scooter Rider
Number of posts: 5 Location: london uk Points: 810 Registration date: 2010-03-13
 | Subject: Pressure Washer Mistake Sat Mar 13, 2010 2:31 pm | |
| hello all
washed my SW today it looks great, made a big mistake though used pressure washer !! now i cant start by beloved any thoughts...............
daffy |
|  | | DennisB Silver Wing Guru
Number of posts: 2397 Points: 4091 Registration date: 2008-12-28
 | Subject: Re: Pressure Washer Mistake Sat Mar 13, 2010 3:09 pm | |
| Hi Daffy, My best advise would be to let it dry out for a couple of days and then try it again. |
|  | | jimjotel Scooter Rider
Number of posts: 77 Age: 62 Location: atlanta ga. Points: 988 Registration date: 2009-12-01
 | Subject: Re: Pressure Washer Mistake Sat Mar 13, 2010 5:42 pm | |
| I had a thought until you said pressure wash, lol, |
|  | | honda_silver Site Admin
Number of posts: 2248 Age: 51 Location: Georgetown, Tx Points: 3589 Registration date: 2008-12-23
 | Subject: Re: Pressure Washer Mistake Sat Mar 13, 2010 5:44 pm | |
| | daffy wrote: | washed my SW today it looks great, made a big mistake though used pressure washer !! now i cant start by beloved any thoughts.............. |
There have been a couple of people who have had problems with a power/pressure washer. Someone had to replace a relay/fuse ... someone else has to replace their ECM after replacing a bunch of other pieces.
As DennisB suggested, let it dry out ... do no rush the dry out.
I would not suggest using a power/pressure washer on the SWing anywhere near the electronics based on the some of the problems that have been reported._________________ Bill - Georgetown TX 07 Silver Wing ABS Clearview w/vent, Givi E96/TB19/E52 with Admore Lighting, Alaskan Leather, Wrist Rests, 3M Solas tape, K&N air, Hyperpro spring, Grip Puppies, Airhawk, Utopia backrest, Stebel, Apexcone HIDs, StingerZ LEDs (w/Backoff WigWag), Knight Rider Sequential LED, NGK Iridium, Power Commander III, Manic Salamander, Saeng mirrors, Garmin Zumo 660, Dark-Side Sumitomo Tire  |
|  | | exavid Silver Wing Rider
Number of posts: 412 Age: 69 Location: Medford, Oregon Points: 1477 Registration date: 2009-07-17
 | Subject: Re: Pressure Washer Mistake Sat Mar 13, 2010 8:07 pm | |
| You might try setting a fan near the bike, it will dry faster with some air blowing around it. I never pressure wash any of my motorcycles or my SW. The pressure washer is just too hard on electrical parts particularly connectors. It's also a good way to get water in the fuel system. Unless your bike is really covered in mud a waterless cleaning with Pledge will do wonders. Just use a damp cloth to wipe off any heavy dirt and then spritz the bike a bit at a time with Lemon Pledge and buff with an old towel. It will leave a very nicely shined bike. With Pledge there's no white residue as often shows up after waxing with car wax. It makes the bike smell good too. |
|  | | tankyuong Touring Scooter Rider
Number of posts: 387 Age: 37 Location: Missouri Points: 1624 Registration date: 2009-07-11
 | Subject: Re: Pressure Washer Mistake Sat Mar 13, 2010 9:15 pm | |
 | Subject: Re: Pressure Washer Mistake Sat Mar 13, 2010 10:22 pm | |
| | tankyuong wrote: | | high air pressure hose |
I thought high air pressure hose could still have a lot of moisture content?? If so you could still be causing more problems._________________ Bill - Georgetown TX 07 Silver Wing ABS Clearview w/vent, Givi E96/TB19/E52 with Admore Lighting, Alaskan Leather, Wrist Rests, 3M Solas tape, K&N air, Hyperpro spring, Grip Puppies, Airhawk, Utopia backrest, Stebel, Apexcone HIDs, StingerZ LEDs (w/Backoff WigWag), Knight Rider Sequential LED, NGK Iridium, Power Commander III, Manic Salamander, Saeng mirrors, Garmin Zumo 660, Dark-Side Sumitomo Tire  |
|  | | jdeereanton Silver Wing Guru
Number of posts: 1767 Age: 74 Location: Huntsville, AL Points: 3053 Registration date: 2008-12-24
 | Subject: Re: Pressure Washer Mistake Sun Mar 14, 2010 4:57 am | |
| Once this is done, time may be the only cure. I have never used a pressure washer on the scoots. I've seen one used on an M1 Abrams and it really messed up the optics. Too much force, stick with a low flow hose. the rags, sponges, soft brushes remove the dirt, not the water pressure.
Drying is simple with a leaf blower and a towel. Remember that the leaf blower can generate a lot of pressure if you get too close with it. I keep the blower at least 18" away from the surface of the bike. No problems to date. |
|  | | daffy Scooter Rider
 | Subject: Re: Pressure Washer Mistake Sun Mar 14, 2010 3:07 pm | |
| many thanks to everyone who replied , the good news is the problem is solved my swing is OK
I have an embarrassing confession to make, the pressure washer never caused the problem I DID, just before i started washing my SW I wheeled it backwards and accidently hit the emergency on / off switch, because at the moment I have hand muffs on my handles I never noticed what I had done
I know what you must all be thinking ........................
cheers Daffy |
 | Subject: Re: Pressure Washer Mistake Sun Mar 14, 2010 3:32 pm | |
| I've done that too. As has my wife. As have many others I'm sure. |
 | Subject: Re: Pressure Washer Mistake Sun Mar 14, 2010 4:33 pm | |
| Done that before too, after about the second or third time, I started checking it when it wouldnt start. But the first time it drove me nuts. A brand new bike and wont start, lol, too bad the switch comes in handy for emergencies. |
 | Subject: Re: Pressure Washer Mistake Sun Mar 14, 2010 4:57 pm | |
| | daffy wrote: | many thanks to everyone who replied , the good news is the problem is solved my swing is OK
I know what you must all be thinking ........................ |
I am thinking this is good news._________________ Bill - Georgetown TX 07 Silver Wing ABS Clearview w/vent, Givi E96/TB19/E52 with Admore Lighting, Alaskan Leather, Wrist Rests, 3M Solas tape, K&N air, Hyperpro spring, Grip Puppies, Airhawk, Utopia backrest, Stebel, Apexcone HIDs, StingerZ LEDs (w/Backoff WigWag), Knight Rider Sequential LED, NGK Iridium, Power Commander III, Manic Salamander, Saeng mirrors, Garmin Zumo 660, Dark-Side Sumitomo Tire  |
 | Subject: Re: Pressure Washer Mistake Sun Mar 14, 2010 8:13 pm | |
| Yep, I doubt there's anyone who rides a motorcycle or scooter hasn't joined the 'Kill switch club'. Normally if I'm going to do it I'll wait until I'm at a busy intersection. The SW isn't as bad as the GW for this little trick. The GW's switch is very easy to bump off especially in cold weather when wearing gloves. |
 | Subject: Re: Pressure Washer Mistake Sun Mar 14, 2010 8:14 pm | |
| Don't know what I did but got a double post. |
 | Subject: Re: Pressure Washer Mistake Sun Mar 14, 2010 8:59 pm | |
| | exavid wrote: | | Yep, I doubt there's anyone who rides a motorcycle or scooter hasn't joined the 'Kill switch club'. Normally if I'm going to do it I'll wait until I'm at a busy intersection |
Did you know that if you hit the "Kill switch" while driving the engine stops.
Did you know that if you turn the "Kill switch" back on while driving the engine starts running again without hitting the starter.  _________________ Bill - Georgetown TX 07 Silver Wing ABS Clearview w/vent, Givi E96/TB19/E52 with Admore Lighting, Alaskan Leather, Wrist Rests, 3M Solas tape, K&N air, Hyperpro spring, Grip Puppies, Airhawk, Utopia backrest, Stebel, Apexcone HIDs, StingerZ LEDs (w/Backoff WigWag), Knight Rider Sequential LED, NGK Iridium, Power Commander III, Manic Salamander, Saeng mirrors, Garmin Zumo 660, Dark-Side Sumitomo Tire  |
 | Subject: Re: Pressure Washer Mistake Sun Mar 14, 2010 9:24 pm | |
| just a stupid question, but all of you probably know, if you hit the starter button after your SW is running, your headlight will only flash, any one coming headon will see it and hopefully notice a bike or scooter is approaching even tho honda was silly enuff not to incorperate, emergengency flashers, as most of GPR riders have flashers, this is a bad oversight on honda's part to me. |
 | Subject: Re: Pressure Washer Mistake Sun Mar 14, 2010 9:46 pm | |
| | jimjotel wrote: | | just a stupid question, but all of you probably know, if you hit the starter button after your SW is running, your headlight will only flash, any one coming headon will see it and hopefully notice a bike or scooter is approaching |
I started with this behavior until someone on a side road misunderstood the flash for a "go ahead" signal and started pulling out on me. I had to brake very hard to stop in time ... I no longer flash my lights.
If the car is on the right ... I will push the right handlebar forward to lean to the to the right and then push the left handlebar forward to lean back the other way . I will try to do this atleast twice ... it is not a flash but show the light directly at them to get their attention
| jimjotel wrote: | even tho honda was silly enuff not to incorperate, emergengency flashers, as most of GPR riders have flashers, this is a bad oversight on honda's part to me. |
I wish the SWing had an emergency flasher._________________ Bill - Georgetown TX 07 Silver Wing ABS Clearview w/vent, Givi E96/TB19/E52 with Admore Lighting, Alaskan Leather, Wrist Rests, 3M Solas tape, K&N air, Hyperpro spring, Grip Puppies, Airhawk, Utopia backrest, Stebel, Apexcone HIDs, StingerZ LEDs (w/Backoff WigWag), Knight Rider Sequential LED, NGK Iridium, Power Commander III, Manic Salamander, Saeng mirrors, Garmin Zumo 660, Dark-Side Sumitomo Tire  |
|  | | Scooterian Scooter Rider
Number of posts: 73 Age: 51 Location: Maine Points: 1280 Registration date: 2009-02-03
 | Subject: Re: Pressure Washer Mistake Mon Mar 15, 2010 3:18 am | |
| Now there's a project for someone (DennisB?) if it hasn't already been done.... create a wiring harness, flasher and switch that flashes all the turn signals like an emergency flasher. I'd buy it in a flash. |
|  | | MikeO Site Admin
Number of posts: 1724 Age: 62 Location: Western Europe Points: 2863 Registration date: 2009-06-29
 | Subject: Re: Pressure Washer Mistake Mon Mar 15, 2010 6:39 am | |
| During one of the 'Think Bike' advertising campaigns in the UK it was suggested that bikes approaching cross-roads or side-turnings where cars were waiting to pull out should alter their line on the road so that they were effectively travelling on a diagonal, i.e. moving from crown to kerb and back....but not swerving from side to side! This is supposed to help them be seen because the view is not conventional. I haven't explained it very well but the concept makes sense. _________________ Mike - Riding on the right - riding for pleasure!
 | Subject: Re: Pressure Washer Mistake Mon Mar 15, 2010 9:43 am | |
| | MikeO wrote: | During one of the 'Think Bike' advertising campaigns in the UK it was suggested that bikes approaching cross-roads or side-turnings where cars were waiting to pull out should alter their line on the road so that they were effectively travelling on a diagonal, i.e. moving from crown to kerb and back....but not swerving from side to side! This is supposed to help them be seen because the view is not conventional. I haven't explained it very well but the concept makes sense. |
There are three benefits by not maintaining a straight line
1) Visible light
If you are able to get your headlights over the cager a couple of times ... the visible light may get their attention.
2) Blind spot
Everyone's eye has a blindspot ... depending on how the cager is looking the blindspot may or may not be a factor. If you drive a straight line you may remain within their bindspot. If you alter your straight straight line, besides potentially getting their attention via your headlight ... you may also move outside of the blindspot. By varying you increase chances of not remaining within the blindspot.
3) Fight or flight response
If the driver considers you to known or normal threat they will take less time analyzing the data.
But if you are different, then the time analyzing the data increases.
For example,
a) if the cager believes you might be a (motorcycle) policeman ... they will take more time analyzing
b) if you are not driving in a straight line (since it is not normal) may have to take more time analyzing to determine the risk.
Since I added my high visibility protective gear (which some people quickly thinks is either a policeman or fireman (cause they always ask), 3M solas reflecting tape and been leaning the headlight back-and-forth to get the oncoming drivers attention I have only had 4 people pull out on me (and they were oblivious on their cellphones)._________________ Bill - Georgetown TX 07 Silver Wing ABS Clearview w/vent, Givi E96/TB19/E52 with Admore Lighting, Alaskan Leather, Wrist Rests, 3M Solas tape, K&N air, Hyperpro spring, Grip Puppies, Airhawk, Utopia backrest, Stebel, Apexcone HIDs, StingerZ LEDs (w/Backoff WigWag), Knight Rider Sequential LED, NGK Iridium, Power Commander III, Manic Salamander, Saeng mirrors, Garmin Zumo 660, Dark-Side Sumitomo Tire  |
Similar topics |  |
| | Permissions in this forum: | You cannot reply to topics in this forum
