| February 2012 | | Sun | Mon | Tue | Wed | Thu | Fri | Sat |
| | | | 1 | 2 | 3 | 4 | | 5 | 6 | 7 | 8 | 9 | 10 | 11 | | 12 | 13 | 14 | 15 | 16 | 17 | 18 | | 19 | 20 | 21 | 22 | 23 | 24 | 25 | | 26 | 27 | 28 | 29 | | | | Calendar |
| | | Help with rear tire (swingarm part) removal | |
honda_silver Site Admin
Number of posts: 2111 Age: 51 Location: Georgetown, Tx Points: 3353 Registration date: 2008-12-23
 | Subject: Re: Help with rear tire (swingarm part) removal Fri Mar 05, 2010 9:39 am | |
| | allhondascoots wrote: |
This needs a good cleaning ... and lots of grease.
This looks like it needs to be replaced._________________ Bill - Georgetown TX 07 Silver Wing ABS Clearview w/vent, Givi E96/TB19/E52 with Admore Lighting, Alaskan Leather, Wrist Rests, 3M Solas tape, K&N air, Hyperpro spring, Grip Puppies, Airhawk, Utopia backrest, Stebel, Apexcone HIDs, StingerZ LEDs (w/Backoff WigWag), Knight Rider Sequential LED, NGK Iridium, Power Commander III, Manic Salamander, Saeng mirrors, Garmin Zumo 660, Dark-Side Sumitomo Tire  |
|  | | DennisB Silver Wing Guru
Number of posts: 2300 Age: 61 Location: Glenpool, Oklahoma Points: 3875 Registration date: 2008-12-28
 | Subject: Re: Help with rear tire (swingarm part) removal Fri Mar 05, 2010 9:46 am | |
| That difinitely looks like water intrusion. Not rust, but water oxidation. Some one must have used a power spray washer on the wheels at some time in the past. You might think about replacing the bearring at this point to be on the safe side. Some very fine steal wool and WD-40 will remove it off the axel. Not to much...just a little scrubing, that's all. Then grease it well when you reasemble it. You might want to remove the front wheel at this time and check it out to see if water got into that axel as well. |
|  | | allhondascoots Scooter Rider
Number of posts: 48 Age: 48 Location: 62285 So ILL Points: 772 Registration date: 2010-02-20
 | Subject: Re: Help with rear tire (swingarm part) removal Fri Mar 05, 2010 9:56 am | |
| Thanks for the heads up. I'll look it over carefully, and the front is off already with no problems.. After I clean it up, I'll get a professional opinion here at work before putting it back together. |
 | Subject: Re: Help with rear tire (swingarm part) removal Sun Mar 07, 2010 12:23 pm | |
| Remind me to never change my own tires again. It was much harder (and dirtier) than it looks, even with the right spoons/irons. Got the tires mounted and installed and the bike mostly back together. As far as the seized swing arm, the bearing cleaned up and felt fine, but the axle shaft itself was pitted and kinda rough. I used a bit of emery cloth to smooth out the high spots, cleaned it all up, recoated it all in a bit of grease and it slid right into place with no problem. Of couse it all might fly apart or break off at 60 mph...... No, I'm sure it'll be fine. Thanks again for the helpful info guys. |
 | Subject: Re: Help with rear tire (swingarm part) removal Sun Mar 07, 2010 2:39 pm | |
| | allhondascoots wrote: | Remind me to never change my own tires again. It was much harder (and dirtier) than it looks, even with the right spoons/irons. |
That is why I have my own NoMar Cyclehill tire changer._________________ Bill - Georgetown TX 07 Silver Wing ABS Clearview w/vent, Givi E96/TB19/E52 with Admore Lighting, Alaskan Leather, Wrist Rests, 3M Solas tape, K&N air, Hyperpro spring, Grip Puppies, Airhawk, Utopia backrest, Stebel, Apexcone HIDs, StingerZ LEDs (w/Backoff WigWag), Knight Rider Sequential LED, NGK Iridium, Power Commander III, Manic Salamander, Saeng mirrors, Garmin Zumo 660, Dark-Side Sumitomo Tire  |
|  | | john123 Maxi-Scooter Rider
Number of posts: 116 Age: 63 Location: Santa Barbara California Points: 877 Registration date: 2010-02-21
 | Subject: Re: Help with rear tire (swingarm part) removal Wed Mar 17, 2010 6:22 pm | |
| Oh my gosh! With all that information and my head is spinning. The pictures and all the informative information regarding wheel removal and oil types is fantastic. I do use straight synthetic (amsoil 10-30) but now realize I should be using a higher grade. I don't need a tire replacement at this time but will soon and I am glad to have all this information at hand. Thanks to all for the GRATE information. |
Similar topics |  |
| | Permissions in this forum: | You cannot reply to topics in this forum
