Honda Silver Wing Forum
» Mud Flap on front wheel
by Daboo Yesterday at 6:52 pm
» Seat latch stuck this morning
by tinman Yesterday at 6:44 pm
» Now that's a bike!
by joncallihan Yesterday at 4:21 pm
» Another battery brand and source.
by Windrider Yesterday at 6:06 am
» New Honda 700 fourm
by JeffR_ Sun Feb 05, 2012 11:33 pm
» Putting in an offer on a 2009
by tinman Sun Feb 05, 2012 8:33 pm
» shortening windshield
by JeffR_ Sun Feb 05, 2012 6:57 pm
» Birthday Wishes to dspevack
by JeffR_ Sun Feb 05, 2012 6:13 pm
» Need hand warmers for Silverwing
by alfadave Sun Feb 05, 2012 5:55 pm
» Kuryakin grips
by CSN Sun Feb 05, 2012 3:47 pm
» Left glove box lid
by Cosmic_Jumper Sun Feb 05, 2012 2:16 pm
» missionary positioning
by "Hi Yo" Sun Feb 05, 2012 1:51 pm
February 2012
SunMonTueWedThuFriSat
   1234
567891011
12131415161718
19202122232425
26272829
CalendarCalendar
 Temp & Voltage Meters Mounted to Brake Resevoir Cover
Goto page : 1, 2  Next
Number of posts: 2300
Registration date: 2008-12-28
PostSubject: Re: Temp & Voltage Meters Mounted to Brake Resevoir Cover   Tue Feb 16, 2010 5:12 pm
All, I put together a information sheet for any body that's interested.
Thank You
mickey
Number of posts: 225
Registration date: 2009-05-06
PostSubject: Re: Temp & Voltage Meters Mounted to Brake Resevoir Cover   Tue Feb 16, 2010 6:48 pm
Here's something for you to play with, Dennis: http://www.mglavionics.co.za/
Made for ultralight aircraft, and intended to survive the elements while being lightweight and reliable. Monitor several temperatures and pressures simultaneously.
WHY? Because you CAN, that's why.
You can even mount up one of their "glass cockpit" gadgets and pretend you're Sky Pilot in the World of Tomorrow. Your altitude above ground level will never change (hopefully) but everything else would be functional. I suppose if a WAAS-activated GPS is accurate enough you could even hook up a single-axis autopilot to your handlebars, set the cruise control, and take a nap. I wouldn't recommend it though.
PostSubject: Re: Temp & Voltage Meters Mounted to Brake Resevoir Cover   Tue Feb 16, 2010 7:20 pm
Mickey,
Very impressive...but you need to take a few pictures so we can all see your installation on your scooters handlebars.
If you have never seen the cockpit on an L1011-TriStar...I sure did when I worked at Lockheed Aircraft back in the late 70's. I was a electrical Engineer with Lockheed back then...now that was some AVIONICS. One GREAT Aircraft!
mickey
PostSubject: Re: Temp & Voltage Meters Mounted to Brake Resevoir Cover   Tue Feb 16, 2010 8:53 pm
My cousin flies for Southwest and says the avionics that garage kit aircraft builders are using these days makes the panel in his 737 look like an abacus. Those MGL guys are doing some amazing things. Just ONE guy, actually. He even wrote the operating system because he didn't trust the stability of any of the available ones. (Can you imagine trusting your life during a dodgy precision approach in hard IMC to something running Windows? Gives a whole new meaning to "blue screen of death.")
You could have all kinds of fun hooking up instruments that are intended for experimental aircraft.
Number of posts: 1477
Registration date: 2009-07-26
PostSubject: Re: Temp & Voltage Meters Mounted to Brake Resevoir Cover   Wed Feb 17, 2010 3:25 am
Dennis, a question.
Where does have you positioned the temperature sensor?
If I have missed it I appologise!
Doug
http://www.facebook.com/Waspie41
PostSubject: Re: Temp & Voltage Meters Mounted to Brake Resevoir Cover   Wed Feb 17, 2010 5:52 am
Hi Doug,
Thank's for asking.
I have my temp sensor and the power wires routed into the top of the handlebars removable cover, tie-wraped to the handlebars, under the cover. Temp sensor cable then loops back through the top opening of the cover and gets black tie-wraped to the mirror stem and exposed to the air temperature sample at that point. A person can experiment around with the sensor location to find the best location.
PostSubject: Re: Temp & Voltage Meters Mounted to Brake Resevoir Cover   Wed Feb 17, 2010 7:18 am
Thanks Dennis, glad you understood my badly written question.
You will have to excuse my ignorance now! You have the sensor at the base of the mirror exposed to the outside air?
Would not the air during forward motion effect the temperature indicated on your gauge. I am thinking along the lines of wind chill! We all know when we ride the speed that as we ride, artificially drops the temperature. Please no-one mention kinetic heat - I don't think even on a 'Wing' we ride that fast.
Cars, (UK), have their sensors placed behind the mirror shroud, so is not directly sited in the airflow.
I was thinking, depending on the size of the sensor that it may be worth attaching around the handlebar hub!
Only my thoughts, please no-one think I am criticising, I am not, just wanting to add to Dennis's great idea. If I'm wrong - I 'm wrong, simple as that. Look forward to others views.
Doug
PostSubject: Re: Temp & Voltage Meters Mounted to Brake Resevoir Cover   Wed Feb 17, 2010 8:29 am
Hi Doug,
Two things a person needs to keep in mined is heat coming from sunlight and evaporative water cooling. (Water found in the air around us all the time). The big culprit being the Suns heat. The thermalcouple on this unit is encapsulated in what looks like a small chrome plated case. Chrome platting does a pretty good job of reflecting the Sun's radiant heat, but to be far, I was thinking of using some white heat shrink installed over the sensor to give it a better chance of a tighter temperature range reading.
PostSubject: Re: Temp & Voltage Meters Mounted to Brake Resevoir Cover   Wed Feb 17, 2010 9:25 am
Thank you again Dennis, it does sound like the chrome plating will do the job of shielding from the effects of wind and sun.
Sounds like you have a winning mod there.
You guys over there will never stop amazing me at the mods you come up with. I am regretting casting off my aviation, airframe/engine trade.
Maybe when Mrs Waspie stops leaving me work around the house I will get time to spend on the 'Wing'.
Splendid job Dennis, I always look forward to your next project. Keep up with the excellent work.
Doug
PostSubject: Re: Temp & Voltage Meters Mounted to Brake Resevoir Cover   Wed Feb 17, 2010 10:22 am
Just got back from the local Honda Bike shop here in Glenpool, The owner was busy doing a trike conversion on a GW and didn't have alot of time to talk, but did look at it...He LIKED IT! Hurray! He wanted my little product flier and said he would show it to a few people.
If you've looked at the M/C and Scooter digital Temperature and voltage displays (the one's you can see at night) offered these days, they range from $350.00 to $56.00 and you need to cut the hole for the display and drill a hole for a switch.
My little Digital Voltage and Temperature gauges sell for $67.00 each ($128.00 a set)and if you sell your scooter, you just remove it and mount it on your new Honda.
If you choose to buy both the Digital Voltage and Temperature gauges $128.00 for both.
For USA orders, shipping will be USPS Priority Mail for $6.00 USD .
For international orders (PayPal), shipping will be USPS Mail Servise for $10.00 USD.
mickey
PostSubject: Re: Temp & Voltage Meters Mounted to Brake Resevoir Cover   Wed Feb 17, 2010 6:39 pm
Doug
Moving air only affects the probe if the probe is wet. Then it becomes a barometer.
Emeskay
Registration date: 2009-06-15
PostSubject: Re: Temp & Voltage Meters Mounted to Brake Resevoir Cover   Thu Feb 18, 2010 8:37 am
Dennis,
Would these work on my husband's BMW? He bought himself a fancy top box that puts a drain on his battery, and it seems like it would be a great thing for him to have.
Thanks,
M-
PostSubject: Re: Temp & Voltage Meters Mounted to Brake Resevoir Cover   Thu Feb 18, 2010 10:05 am
Hi Mandy,
Thank's for interest.
The Resevoir covers are not the same...I'm sure. To get the Voltage gauge to work on a BMW, I would need to know what the BMW brake resevoir looked like. Is it rectangular like the Honda's and what the dimensions of the cover and the distance between the center of the covers mounting holes? Is there 2 screws or 4 (1 in each corner)?
It might work...but I would need to use a BMW resevoir cover.
PostSubject: Re: Temp & Voltage Meters Mounted to Brake Resevoir Cover   Sat Feb 20, 2010 4:28 pm
Got the new scooter dc volt meter in and have it installed.
It's amazing how much voltage is pulled by different things on the scooter. At idle the new voltage meter shows 14.3 Volts DC and jumps to 14.4 when I increase the RPM's. When I turn on the driving lights the system drops down to 13.8 volts at idle.
Just thought you'll might like to see a picture or two. It been trying to rain all day and the temperature is 53 F.
Pulled the scooter out of the garage, for a minute, to get a couple of shots.
Number of posts: 1244
Registration date: 2009-01-10
PostSubject: Re: Temp & Voltage Meters Mounted to Brake Resevoir Cover   Sun Feb 21, 2010 6:19 am
Good looking mod Dennis. I want the set so add me to the list of potential customers. I am curious... the toggle switch on the top for the temp guage toggles from F to C temps. What does it do for voltage?
I would like to see a photo of your scoot from a distance that shows both meters installed. Or you can come down here for a visit. I hope you are too busy to do the visit, so get the camera out again.
PostSubject: Re: Temp & Voltage Meters Mounted to Brake Resevoir Cover   Sun Feb 21, 2010 6:52 am
Hi Gary,
Been a motorcycle rider for almost 50 years now, some of you even more. Having certain options is a good thing when your on the road...like being able to control your bikes accessories and do it safely.
The small waterproof switch on the top of the Voltage and Temp units is for ON/OFF and I placed them there so they would be easy to get too when a rider is moving down the road.
Searching for a small, "hidden" switch at a high rate of speed is not safe...or at any speed for that mater. So that's why I placed them on top and easy for a bike rider to get to.
I think It's a great deal for the Voltage or Temp Meter that you can see at night at only $67.00 each.
As soon as it gets done raining, I'll get more pictures. I was thinking of taking a picture at night so you'll can see how nice this looks.
PostSubject: Re: Temp & Voltage Meters Mounted to Brake Resevoir Cover   Sun Feb 21, 2010 1:28 pm
Yeah I was in a hurry this morning when I sent the last post... I was thinking the button on back was the on/off switch and the toggle on top was the c to f. Now I understand better after going back and re reading the post earlier.... thanks for the info.
PostSubject: Re: Temp & Voltage Meters Mounted to Brake Resevoir Cover   Sun Feb 21, 2010 2:05 pm
Hi Gary,
Took your good advice and grabbed a few more pictures of the units installed on the scooter:
Emeskay
PostSubject: Re: Temp & Voltage Meters Mounted to Brake Resevoir Cover   Mon Feb 22, 2010 12:40 pm
DennisB wrote:
Hi Mandy,
Right now, the bikes are surrounded by snow piles, but as soon as I can get to them, I'll take a picture of the brake reservoir and measure it.
Thanks, Dennis.
Page 1 of 2Goto page : 1, 2  Next
» Gentex autodim with compas, temp sensor and homelink
» SEAT COVER
» TruXmart Tri Fold Tonneau Cover
» Brake line replacement HELP!
» EVO UPGRADED BRAKE KIT FRONT - USE WITH 17x8J ET25 TOMBINOS
Honda Silver Wing Forum :: Honda Silver Wing :: Accessories & Modifications-
