Hi, Welcome to the Silverwing 600 Forum. We ask that you be polite and also introduce yourself on your 1st post. The members are friendly and helpful so just have fun. There is www.maxi-scoots.com site that is geared for all scooters and motorcycles.
HomeGallerySearchRegisterLog in
» Finally.......
Repairing panel damage video I_icon_minitimeby Meldrew Today at 4:12 am
» Buying an ‘06 from RumbleOn
Repairing panel damage video I_icon_minitimeby Mech 1 twa Yesterday at 8:34 pm
» New to Me '09 Silverwing
Repairing panel damage video I_icon_minitimeby EvilTwin Yesterday at 8:00 pm
» Spring, two year since my SilverWing went away
Repairing panel damage video I_icon_minitimeby bikehiker Yesterday at 1:08 pm
» Hello from Virginia
Repairing panel damage video I_icon_minitimeby sonuvabug Yesterday at 10:35 am
» Belt Squeal?
Repairing panel damage video I_icon_minitimeby exavid Sun Jan 26, 2020 5:18 pm
» Play the is that me game :)
Repairing panel damage video I_icon_minitimeby Mike from NS Sun Jan 26, 2020 7:08 am
» Aftermarket exhaust.
Repairing panel damage video I_icon_minitimeby Leena H Fri Jan 24, 2020 4:10 am
» Beef up exhaust sound for Silver Wing?
Repairing panel damage video I_icon_minitimeby oldwingguy Thu Jan 23, 2020 9:42 pm
» Honda Integra engine noise
Repairing panel damage video I_icon_minitimeby MrHyde Thu Jan 23, 2020 7:01 am
Share
Number of posts : 3280
Repairing panel damage video Empty
PostSubject: Repairing panel damage video   Repairing panel damage video I_icon_minitimeSat Nov 23, 2019 8:14 am
While IMHO Plast-Aid is the best product for repairing tupperware, here is an very interesting alternative suggested by “Sonuvabug”.
https://www.youtube.com/watch?v=RWvpZaKBBfI
Hiyo
Number of posts : 33
Registration date : 2019-10-22
PostSubject: repair reply   Repairing panel damage video I_icon_minitimeTue Dec 03, 2019 8:42 pm
Worth a watch. Been using JB Weld Plastic bond epoxy myself. Seems biggest thing to do with it is to take it down to plastic if possible. I remade some tabs from windshield plastic. Seems with the JB it adheres to plastic better than paint. The fiberglass and cyanoacrylate looks like it would work well. I may do that and reinforce with epoxy as well.
Number of posts : 1403
PostSubject: Re: Repairing panel damage video   Repairing panel damage video I_icon_minitimeWed Dec 04, 2019 12:00 am
Very interesting video. Well worth the watch if panel repair, and other stuff, is needed.
Number of posts : 2510
PostSubject: Re: Repairing panel damage video   Repairing panel damage video I_icon_minitimeWed Dec 04, 2019 4:12 pm
I've repaired quite a few tupperware parts in my old shop with ABS cement. I'm not sure about SWs but the GWs plastic is ABS. ABS cement makes a plastic weld on ABS plastic as strong as the original plastic. I tried various other cements and epoxy glues. One test I use is to put a dollop about the size of a small Hershey's Kiss candy on a piece of the plastic and then once it has cured overnight try to pry the dollop off the surface of the plastic. Of all the adhesives I tried the ABS cement had the strongest bond. During the nine years I had my Goldwing restoration business I repaired and even molded patches to holes in original platic parts on Goldwings and never had a failure.
ABS cement is not expensive and most hardware stores that sell black drain pipes will stock the stuff. The cement is a bit thicker than honey and cures overnight if the repair isn't too thick. In fact if you need to build up a thick repair it's better to do it in fairly thin layers allowing each layer to harden before applying the next. Since the ABS cement is the same thing as the bike plastic softened with a solvent it can soften the areas around the patch if you put too much on at one time.
The cement dries by evaporation of the solvent, too much will seal off the layer before all the solvent has evaporated. If that happens it will be days before it's hard and it might warp the underlying material.
Other than that it's a very good repair medium, inexpensive and easy to use. You can also mix ABS cement with ABS dust made from grinding or sanding a ABS pipe fitting. I've even replace missing dabs with the stuff using a bit of fiberglas cloth and building it up with several applications of ABS cement. I repaired a Goldwing trunk lid with a 3" hole in it that was strong and invisible once done.
Hiyo
PostSubject: Dead    Repairing panel damage video I_icon_minitimeSun Dec 08, 2019 1:39 pm
Dead 🐎
Sepp
Sepp
Number of posts : 123
Registration date : 2019-10-09
PostSubject: Re: Repairing panel damage video   Repairing panel damage video I_icon_minitimeSun Dec 08, 2019 10:06 pm
ea forum is a living thing, exiting when all is new and everybody pitches in.
Over the years the dynamic changes, old members leave new members come.
Knowledge from the initial crew gets passede on or forgotten.
If somebody buys an 18 year old bike it might still be totally new to him and he has all the questions the initial crew had (plus some more)
So be gentle to the newbies.
there are / will be fields where you are the newbie, think how you want to be treated.
be nice to the new person, the world outside is already crazy enough.
https://hosiwi.blogspot.com/
PostSubject: Re: Repairing panel damage video   Repairing panel damage video I_icon_minitimeSun Dec 08, 2019 11:55 pm
I'm aware that most of my post on ABS repair has been posted before. I'm sorry some members find it's repetition annoying. I merely wanted to help someone who hadn't seen the original posting from some time ago or might not have been successful in finding the old post.
PostSubject: Re: Repairing panel damage video   Repairing panel damage video I_icon_minitimeMon Dec 09, 2019 10:02 am
A few hints & tips about repairing tupperware is not beating a dead horse. It kinda follows the ebb & flow of new members.
Plenty of discussions here on the subject. Use the Search functions.
This topic is now locked.
Now oil filters...
» VIDEO SHOWING HOW TO FILLET DIFFERENT SPECIES OF FISH
» FCUM live streaming video
» FISH DAMAGE
» big col on world of armwrestling plus video footage
» Short Dirty Trutle Video
