Hi, Welcome to the Silverwing 600 Forum. We ask that you be polite and also introduce yourself on your 1st post. The members are friendly and helpful so just have fun. There is www.maxi-scoots.com site that is geared for all scooters and motorcycles.
HomeGallerySearchRegisterLog in
» Please help to decide
Bad Brakeswitch I_icon_minitimeby rustysdream Today at 5:30 pm
» 2009 Silverwing for sale
Bad Brakeswitch I_icon_minitimeby EvilTwin Today at 8:44 am
» Installed a C.L.M. lock on Swing.
Bad Brakeswitch I_icon_minitimeby GoonerKev Today at 3:49 am
» Headlights off
Bad Brakeswitch I_icon_minitimeby LECHETTAN Today at 2:25 am
» WANTED: Used Corbin Seat for 2009 Honda Silverwing
Bad Brakeswitch I_icon_minitimeby 324woody Today at 1:09 am
» Hello from NY
Bad Brakeswitch I_icon_minitimeby AldusFran Yesterday at 5:57 pm
» New member from Canada
Bad Brakeswitch I_icon_minitimeby rustysdream Yesterday at 5:55 pm
» Not Cold Enough
Bad Brakeswitch I_icon_minitimeby "Hi Yo" Yesterday at 11:05 am
» left signal turn
Bad Brakeswitch I_icon_minitimeby Loosemarbles Yesterday at 5:22 am
» New Honda Adventure Scooter
Bad Brakeswitch I_icon_minitimeby bikehiker Wed Feb 26, 2020 9:39 pm
Share
 Bad Brakeswitch
DustyTrails8749
DustyTrails8749
Number of posts : 9
Registration date : 2019-08-14
Bad Brakeswitch Empty
PostSubject: Bad Brakeswitch   Bad Brakeswitch I_icon_minitimeThu Aug 22, 2019 7:49 pm
Where is the best place to get a replacement rear brake switch?
Number of posts : 863
PostSubject: Re: Bad Brakeswitch   Bad Brakeswitch I_icon_minitimeThu Aug 22, 2019 8:29 pm
Try squirting some electronic contact cleaner and work the brake handle. Some members also use WD-40.
Number of posts : 1420
PostSubject: Re: Bad Brakeswitch   Bad Brakeswitch I_icon_minitimeThu Aug 22, 2019 9:37 pm
WD-40 worked good for me in both brake levers, the turn signal switch and all the key locks.
Number of posts : 1410
PostSubject: Re: Bad Brakeswitch   Bad Brakeswitch I_icon_minitimeThu Aug 22, 2019 9:50 pm
Partszilla has done well for me, if the WD40 doesn't work and you want an electrical switch cleaner make sure it's safe for plastics.
Number of posts : 824
PostSubject: Re: Bad Brakeswitch   Bad Brakeswitch I_icon_minitimeFri Aug 23, 2019 7:13 am
Search OEM part # 35340-KFG-003, 35340-KFG-000
Same item is used on FSC600 Silver Wing, NSS300 Forza, NSS250 Reflex/Reflex Sport and PS250 Big Ruckus.
Number of posts : 2855
PostSubject: Re: Bad Brakeswitch   Bad Brakeswitch I_icon_minitimeFri Aug 23, 2019 8:44 am
Honda dealer
Number of posts : 3297
PostSubject: Re: Bad Brakeswitch   Bad Brakeswitch I_icon_minitimeFri Aug 23, 2019 11:13 am
I had a brake switch failure. Actually both switches failed, though probably not at the same time. It was only discovered during a group ride when the guy behind me complimented me on never using my brakes on a twisty down hill ride. Evidently not even at the stop sign at the bottom of the run.
Once returned to base we meter tested everything and discovered the two failed switches. Given the circumstances it is unnerving to think that if the left brake switch totally failed it would have prevented me from starting the scoot. So now I’ve taken to carrying that left side brake/start switch as a spare.
Now I’m curious wether the left switch could also fit in place of the right brake switch? Electrically the same but physically different?
Number of posts : 363
PostSubject: Re: Bad Brakeswitch   Bad Brakeswitch I_icon_minitimeFri Aug 23, 2019 11:18 am
Previous bike brake switch failure: Cleaned up with WD40. Fixed it.
Current SWing rear brake switch failure. Started to take apart and found one wire was not connected. Connected wire and it's working fine.
Bad Brakeswitch
Honda Silver Wing Scooter Forum :: General :: Kurt's Korner-
