» interior light with manual switch
by Old Limey Today at 9:03 am
» Silverwing or Burgman 650....not again!
by Meldrew Today at 6:56 am
» Headlight Question
by LarryB Today at 6:19 am
» UK ride posting
by Duke1 Today at 3:17 am
» I Was Bored
by Tagg Yesterday at 11:11 pm
» Stock seat mods
by honda_silver Yesterday at 8:50 pm
» Engine Turn off
by honda_silver Yesterday at 6:17 pm
» Does anyone have the Side Case Attachments on SW 600
by Charlie2nice Yesterday at 5:32 pm
» Front fork seal leaking
by Waspie Yesterday at 1:01 pm
» Corbin Seat More Leg Room
by honda_silver Yesterday at 10:17 am
» Tailgaters - What to do?
by Walt981 Mon May 21, 2012 11:58 pm
» Today IS a good news day
by johnd Mon May 21, 2012 9:32 pm
 Heated grips
Goto page : Previous  1, 2
Hammy
Number of posts: 337
Registration date: 2010-05-22
PostSubject: Re: Heated grips   Thu Oct 21, 2010 5:28 pm
Re: the heated liners... All I can say is be careful. I had a pair of Gerbings glove liners before and a few motorcycle buddies who had the same experience as me -- the glove liners can actually burn the back of your hands. I ended up with grill marks after use, and so did a few of my friends. We all switched to regular heated gloves after that and never had that problem.
Speaking of heated gloves, Warm n Safe uses the same connectors as Gerbings and they make the same heated gear that gets branded and sold by First Gear and Tourmaster. They have passenger gloves which heat both the front and back of the hand, whereas the regular heated gloves only heat the back of the hand.
mitch
Number of posts: 42
Registration date: 2010-09-10
PostSubject: Re: Heated grips   Mon Nov 15, 2010 4:03 am
I am contemplating having heated grips fitted.
Any feedback would be appreciated on :-
Cost to supply / cost to fit and effectiveness of the different market brands.
I suppose the bespoke Honda grips would be the ones to go for / be suited but they appear pricey.
Number of posts: 1724
Registration date: 2009-06-29
PostSubject: Re: Heated grips   Mon Nov 15, 2010 4:16 am
I have Honda heated grips; they were ordered and fitted pre-delivery so I don't know the cost off-hand.
I don't often use them but find them very effective at the point where, if the weather is very wet or cold and my little pinkies are going numb, they are invaluable.
There's a modicom of psychology, too - I know I can warm up my hands if I need to.
The grips themselves are quite hard to the touch so I slipped Grip-Puppies over them. That cured the problem (and the niggling vibration) - someone, Dennis I think, suggested using foam pipe-insulation as a cheaper but effective alternative.
I would not be without them even though I use them infrequently.
HTH
_________________
Mike - Riding on the right - riding for pleasure!
"All that is necessary for the triumph of evil is that good men do nothing."
Edmund Burke
Excell
Number of posts: 143
Registration date: 2009-05-06
PostSubject: Re: Heated grips   Mon Nov 15, 2010 5:15 am
I have them ,they give me an extra month of riding .i would not want to be with out them . My hands still get cold even with them as I have circulation problems . I can't see you being sorry if you get them .
Number of posts: 1738
Registration date: 2009-07-26
PostSubject: Re: Heated grips   Mon Nov 15, 2010 9:29 am
As an aside, when I was flying for a living, one of my pilots had a problem with heated liners. Every time he pressed the transmit button on the cyclic he received a electric shock, so much, that on one sortie he burned a hole in middle finger on his right hand!!!!
Imagine if every time you braked you received the same treatment!!!! Rolling Eyes No
http://www.facebook.com/Waspie41
aorfarmer
Number of posts: 1
Registration date: 2010-09-05
PostSubject: Re: Heated grips   Sat Feb 19, 2011 6:19 pm
Well looking at the dates on this topic, I maybe a bit late but while I was doing research on Heated Grips, I found the below link.
http://www.heatedgrips.org/heated-grips-selecting-the-best-ones-for-you/
I hope it helps.
Aorfarmer
Number of posts: 412
Registration date: 2009-07-17
PostSubject: Re: Heated grips   Sat Feb 19, 2011 9:47 pm
There are quite a few riders around here who have the Gerbings gear. So far none of them have had a problem. I have heard of a case where a controller failed and overheated a jacket liner but that's pretty easy to disconnect when needed. The reason I prefer the gloves to the heated grips is that I use them on two bikes, my 1800 and the SW. Much cheaper to switch back and forth with the gloves than install heated grips on both.
Darkeswinger
Number of posts: 35
Registration date: 2010-06-11
PostSubject: Re: Heated grips   Mon Feb 21, 2011 10:54 am
I installed the Oxford removable heated grips, and had my first test ride on Saturday (air temp 43 degrees). Worked so well that I had to turn them off after about 10 minutes. They stayed warm for another 15 minutes or so after that. I hooked them into a switched fuse, so they cannot be on when the ignition is off. Great investment!
Heated grips
Page 2 of 2Goto page : Previous  1, 2
» what glue for grips
» K75S Aftermarket Heated Grips
» wiring up Oxford heated grips to the ignition switch
» Oxford Heated Grips
» Need confirmatino of wiring for heated grips
